Thanks for all the help, a rebuilt starter did the trick! Now I'm having trouble with my carburetors...see this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/336381-my-webers-gushing-gas-top-whats-wrong.html#post3166969 You guys are great! |
Starter Whirs, but nothing
I have a similar problem, and I've been advised by another forum to remove the starter, use penetrating oil to clean and lubricate the Benix and then use TEFLON Multi-Use Spray Lubricant all around the shaft area allowing the gear to fully move forward to engage the flywheel.
Will be trying that shortly. |
| All times are GMT -8. The time now is 11:36 AM. |
