Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
weber fuel line diagram?
Does anyone have a good picture of a weber fuel line install using an fittings in a recirculating system?
I'm using my CIS fuel pump and have an lines running to the old CIS system. A parts list of whats needed on the carbs would be cool too. Think I saw that PMO has some bars to eliminate the banjo fittings. Figure I'll keep the bosch fuel filter in the system and plum from there.
I got this with the carbs, looks like what PMO sells, but can it be used with the high pressure sytem?
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 03-11-2007, 01:14 PM
rfuerst911sc's Avatar
I just had PMO carbs installed on my 3.0 SC and we ordered the carbs with AN fittings. If you send me a PM with your email address I'll take some digital pics of the install I have. It's a very clean looking install. I don't care for the look of hose clamps on fuel lines.
Old 03-11-2007, 02:48 PM
my stock fuel and return lines have a connector in the tranny area. I disconnected the lines going towards the engine compartment and brought them into a hose shop. They removed the stock connector and installed them on stainless 6AN lines.
ask the hose shop if they have the the contraption to make the connectors sealed to the 6AN lines.. many don't.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-11-2007, 10:24 PM
