76carrera3.0's Avatar
SKF Bearing #
Can any one on the forum give the SKF rear wheel bearing number for a 76 911.
Old 03-16-2007, 08:00 AM
SPJ-911's Avatar
I believe you are looking for P/N K800-29138 which is a split inner ring sealed unit 80mm OD x 42mmW x 42mm ID according to my SKF handbook. FAG makes a bearing that will work but as a former SKF engineer I endorse the SKF version. The bearing is still used today on some wheel applications by the way. Should run you around $60 a piece.
Hope that helps.
89 Carrera 3.2L
84 FXRS
Old 03-16-2007, 05:56 PM
