930 rotor machining question
What is recommended minimum thickness for front and rear 1979 930 rotor thichness after machining? Thanks.
30.6/26.6 mm
Are those numbers the same for all 930 thru '89? Just curious cause I may have to do this to my '87 930.
Thanks Bill! SmileWavy
Make sure that an equal amount is taken off on both sides so the rotors stay centered in the calipers.
Also, after machining, install and check the runout with a dial indicator. |
| All times are GMT -8. The time now is 08:24 PM. |
