Eli K's Avatar
Green wire female connector
Hi folks,
My "green wire" disintegrated, including the female plug coming out of the CDI box. I did some searching but didn't find anything conclusive on Pelican. Would a generic amp/bosch connector such as this with pictured female connectors work?
Old 11-11-2006, 11:41 PM
Early_S_Man's Avatar
Porsche Crest
Eli,
Yes. If the green coax cracked out of the CDI unit, it should be replaced all the way to the distributor. Teflon-insulated coax would be preferable, but even PVC would give several years of service before cracking again ... since the Teflon coax is getting pricey these days! Plenum-rated Ethernet coax would work, too.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-12-2006, 07:55 AM
Somatic Negative Optimist
Gunter's Avatar
Eli:
Depending on the year/type, you'll have either 3-pin, or 6-pin connectors from the CDI module.
In the top picture, you are showing a plug that's used for WUR, CSV, AAR and air flow sensor/switch.
Do you intend to use the connectors showing in the second picture to make a new coax-wire?
If so, don't mix up the signal wire with the shield connection.
I think you'll also need the "Pig-tail" coming out of the distributor sold by PP.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-12-2006, 08:28 AM
Eli K's Avatar
Thank you gents. I have a 78 euro SC, which does not have a wire running straight to the CDI box, but instead there is a plug coming out of the harness near the distributor.
I bought the replacement "green wire" from our host, but it appears I also need the plug to solder on to the two loose wires now coming out of the harness, or what used to be a female connector.
I found a plug for around $3 online, and just wanted to double check to make sure it's the right one....
http://www.kayjayco.com/catPConnectors.htm
Old 11-12-2006, 01:39 PM
Porsche Crest
Yep, that 2-wire is the connector that needs to be spliced onto your existing green coax to connect the new green pigtail to ...
And here are the pins that need to be ordered separately:
Warren Hall, Jr.
Old 03-11-2007, 06:59 PM
Eli K's Avatar
Thanks Warren. Did this several months back. Runs like a champ since...
Old 03-12-2007, 09:58 AM
