-   -   Idling Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/335191-idling-problem.html)
arbita1 03-12-2007 09:39 AM
Idling Problem
I've searched a bit, but most of what I am seeing are cold start problems. Here's my situation:
When the car is cold, it will start and then idle high (around 2,500 or so) for about a minute and then the idle will level out to normal. This all I'm sure is normal.
However, after the car is warm (like after a long drive) the next time I start it, it will idle high again for a minute and then when the idle comes down, it will gradually come down to be close to stalling. It may also hestitate a few times when taking off.
Once I drive in the upper RPM's for a little bit the problem goes away.
Any ideas?
