Superman
Guest
Posts: n/a
Hot Tip: Ignition
I just upgraded my stock cap and rotor with 25k miles on them, to a BRAND NEW cap and rotor, and the car just runs a WHOLE lot better. Go figure.
My sister brought her Grand Voyager kidhauler by and the cap looked like there'd been a war in there. She said she just had it 'serviced.' As it turns out, professionals sometimes cut corners.
This is my high-tech, hi-performance tip of the month. Change your cap and rotor if you're like me and sometimes neglect it.
'83 SC
Old 01-02-2001, 03:03 PM
Early_S_Man
Guest
Posts: n/a
Super,
Yep, those new OEM parts sometimes work miracles!
Sort of like the same kind Split-Fire always claims in their ads, only they always compare themselves against an old, worn-out, sooty set of plugs ... and a set of $6 NGK's (not $6 each, a whole set for $6) would also get you the same power 'increase' they claim!!!
Warren Hall
1973 911S Targa
Old 01-02-2001, 03:14 PM
pbs911
Guest
Posts: n/a
I think most of us are guilty of overlooking the simple or the obvious on an occation or two. But the mech for your sister, that's unexcussable!!! If not just dishonest!!!
Paul
78SC Targa
Old 01-02-2001, 05:08 PM
