915 drain and fill plugs
OK I have the 17mm tool. These are steel in the Al tranny case and they don't wanna budge. They soaking in WD 40 now. I am afraid I am gonna ruin the case if I use a breaker bar.
Is there ANOTHER WAY to drain and fill the fluid? like maybe taking of the small plate on the bottom held in with 4 studs? if so how do I fill afterwards? any thought are viewed as helpful here =) |
WD 40 will not help as it really isn't a penetrating oil. The short answer is brute force and a breaker bar. Throw some heat on the case but not on the plug. Keep trying. You need to get the fill plug out first before you drain so you know you can refill with new stuff.
Tony G 2000 Boxster S |
Thanks for the tip, that's my project for the day, too. I don't think the plugs in my car have ever been out, and so far they've resisted brute force.
Paul
1985 911 Carrera Moss Green Metallic Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning |
read this, might help. Also use the search button in the upper right for other threads on this topic.
Dam 915 tranny drain plug!
Are you saying that someone installed a steel VW drain plug in place of the factory aluminum one? If so, consider your self lucky!
Get a 1/2" drive breaker bar, and put a three-foot-long pipe over it. Make sure the recess of the plug is clean and that the 17 mm drive bit fits tightly!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-11-2007 at 06:07 PM.. |
Somatic Negative Optimist
Use penetrating oil (Not WD-40) first and let it soak.
If the plug is really tight, a regular Allen wrench will not work. You'll need to cut a short piece (3") off the long Allan-handle. Then put that piece into a socket with a short extension and a breaker bar. Important: The hex is very shallow, so, when you cut that short piece, leave the edges very sharp so they can bite into the hex. Do the fill plug first, then the drain plug.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
i had a nightmare with mine as well, had to weld a nut to it cause i screwed
up the plug. try this, first tighten it then loosen it. sometimes that works
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) Last edited by jason2guy; 03-11-2007 at 11:24 AM.. |
Use PB Blaster instead of WD40. Tap the plug a few times with a hammer and apply more PB, by tapping you are helping the penetrant get into the threads. Then put as much pipe as you have room for over the allen wrench for leverage. It will come out.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
+1 for PB Blaster. That stuff is amazing...
1984 Targa |
Well, I’ll come back to this next week. Had soaked the fill and drain plugs with PB Blaster about a month ago. No luck with an 18” ratchet with the good, ½” 17mm Allen bit. With the back of the car up on jack stands, tried using a small floor jack to press the ratchet arm up. No luck – it simply lifted the back of the car. Soaked them again with PB, and will try again next week, with the addition of tapping with a hammer and a little heat on the case.
Paul
you are doing the right thing
that may never be enough tho... be prepared for a torch
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Paul:
Grind the tip of the Allen flat so that the sharp edges can bite into the shallow hex.
My 915 plugs have the male hex head, so you can use a regular socket on them. Are these hard to find? I highly recommend them over the Allen head (female) type.
Good luck with the removal!
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
durn for'ner
I have been there as well. Really taxes ones sanity, not to mention ones skin on the knuckles.
The only thing that eventually did it was leverage. A home manufactured looong pipe to go on the key. A real bugger.
Markus Resident Fluffer Carrera '85 |
I helped a friend along who was having the same problem....fought with it for days.
After I position myself underneath the car and take ratchet in hand I realize one small technicality is keeping him in a world of hurt. He was tightening the plug.
Warren & Ron, may you rest in Peace. |
Bill is Dead.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Registered abUser
Here is the method I used to remove mine. As was said, be sure the plug is cleaned out well. If you round the plug and/or the wrench, a trans removal may be in your future.
It's amazing how people over-tighten these plugs almost to the point of cracking the case.
The thread is tapered (like NPT) and requires just a reasonable torque. It can always be tightened a little more should it leake.
2 weeks ago, i rummaged thru the trannies (as in transmissions, not trans-genders
) at partsheaven. i found several of the "outties". purchased them cheaper than buying that big ol honking 17 allen. good luck with the stubborn plug.
poof! gone |
