3rd gear issue on a 915 trans.
I got a problem with 3rd.
It engages fairly smooth, but it will slip out of gear if I let up on the throttle, other wise as long as I'm on it it stays put.
I've got Wayne's 101 and have done a search and will try to adjust the shift rod coupler.
The car has a OEM short shift with new bushings as the PO told me.
Could it be internal?? All other gears work great.
Gino
72 911 coupe 2.7L S Cams/Webers Street/Track
68 912 coupe 1.6L sold
Old 01-05-2007, 05:46 AM
pull up the shifter boot and be sure the shift handle doesn't butt up against the edge of the tower before it's all the way into gear. a coupler length adjustment would fix that. be sure the cylindrical bushing at the end of the shift handle is still in good condition, and check the side bushings in the shift coupler. if nothing shows up there, remove the shift guide fork plate on the bottom of the trans (i assume it's a 915) and see if the fork is loose on the plate. also check for little teeth on the drain plug magnet. that's the simple stuff.
206 637 4071
Old 01-05-2007, 08:17 AM
Thanks John
I'll check all that.
Gino
Old 01-05-2007, 03:03 PM
Finally got to draining the transmission. The shift fork guide was tight but it is worn a bit on both sides.
Here's a couple of pictures.
Would the scoring be causing the slipping out of 3rd gear?
There was some fine shavings in the magnetic plug, along with some kind of gunk, no pict.
Gino
Old 01-11-2007, 10:53 AM
After reading old 915 posts for 2 hours it seems I'm in for a rebuild.
I've ordered a new fork, I'll see how it is on the way to the rebuild shop
Gino
Old 01-11-2007, 05:55 PM
Mahler9th's Avatar
I have some similar damage on my 915 shift fork. I have been searching for the cause. Did yu ever find out what caused this? What was damaged in the transmission?
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-11-2007, 06:54 PM
Mahler9th's Avatar
Has anybody else out there seen this type of damage to a fork that wasn't loose?
Mike
BMWCCA
NASA
Old 02-12-2007, 11:03 AM
that's from the nearest gear rubbing on the fork because the end play in that shaft is excessive, usually because the retainer (tensioning ) plate that holds the 4 point ball bearing tight against the diff housing is worn out. could also be the reason it pops 3rd.
206 637 4071
Old 02-12-2007, 11:35 AM
Mahler9th's Avatar
Is there a spec for end play?
Mike
BMWCCA
NASA
Old 02-12-2007, 03:48 PM
yeah, zero to barely noticeable.
206 637 4071
Old 02-12-2007, 05:58 PM
Mahler9th's Avatar
Figured that. So far I have found the pinion shaft spacer (between fixed 3 and 4) to be 30-40 thou shorter than it should be. Will also be checking the spacer on the input shaft (late style).
Mike
BMWCCA
NASA
Old 02-12-2007, 06:10 PM
check shaft end play. the gears will always have some.
206 637 4071
Old 02-13-2007, 05:06 PM
Tranny has been spit
3rd and 4th gear slider is worn really bad on 3rd side,
Yes that would make slip out of 3rd.
here's a picture of the 3rd side
now one of 4th for comparison
Gino
Old 03-12-2007, 01:44 PM
Geary's Avatar
Wow. That's as worn as I've seen. Aside from the loss of all tooth tips, it's worthwhile observing the amount of metal that's been displaced on each tooth (the little bulge you see on every tooth). There hasn't been room for the gear's engagement teeth to fully engage for many thousands of miles.
This odd wear is usually caused by speed shifting, but can also be greatly accelerated by the use of synthetic oil.
Old 03-12-2007, 02:11 PM
Must have been speed shifting as other teeth on 1-2, 4 and 5th
are Ok, well at least much much better.
Was surprised at the "buldges" myself.
Gino
Old 03-12-2007, 02:43 PM
