Broken rear sway bar mounts on 1989 Carrera
I have a broken rear sway bar mount on the driver side and it appears that the left side has been repaired in the past. I just purchased the car and hear there is a upgraded mount that has to be welded on (must grind old mount off and weld new one on). Is the repair part that Performance Parts sells the correct part, does our host sell the part, and can a good TIG welder make this repair look professional?
Friend of Warren
Common problem on the Carreras. I think this thread is the second one in a week regarding torn out sway bar mounts. Pelican Parts sells the heavy duty sway bar mount. Go ahead and get one for each side. Easy to weld in.
Kurt V No more Porsches, but a revolving number of motorcycles. |
3.4 Bigger is better
Do it once, use the WEVO cast sway bar mount. The factory upgrade mount is still just stamped steel and will eventually break as well. The old ones need to be ground off and weld the new ones on.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Diss Member
+1 on the WEVOs. They are an excellent way to keep a common problem from coming back.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Just looked at their website, they do look like a quality upgrade, I guess you use your factory bracket to bolt to their mount?
Skunk works
seems like a common problem
just had this repaired on my 76 & fitted wevo kit while i was doing some other suspension work
964 RS-4 |
I can't seem to locate these on the WEVO site...anyone have a link or a point in the right direction?
Tony G 2000 Boxster S |
Ditto on the Wevos. I installed the "improved" factory mounts, both sides, PLUS the Smart Racing reinforcements, and still tore one. Don't screw around with this more than once. Wevo is also equal to or cheaper than the factory part, especially if you add the Smart reinforcement.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
The updated mounts are fine [ they are reinforced.] To say that because they are stamped steel they aren't any good is in my opinion incorrect. Porsche took what was essentially an L shape and boxed it with a gusset, making it very strong. Nothing wrong with the cast pieces, but I think your money could be better spent. Just my opinion.
The Wevo mount is almost the same price as the updated factory piece. No-brainer IMHO.
Diss Member
Here is a direct link: http://www.wevo.com/Products/ChassisProducts/WevoChassisProducts-RARBConsoles.htm
Ahhh....thank you! Mine are still original...I've gone to 29mm t-bars, so I don't know if that will take some of the stress off of the sway bar mounts. If/when they do break...WEVOs!
WEVO MOUNTS
MIG welding will be better than TIG for this job due to the dirty metal, galvanizing, gaps, etc. |
