Blizzard
Guest
Posts: n/a
Torque steer
My 1986 911 steers to the left under moderate acceleration. I have checked tire inflation, brakes, etc. and all seems to be OK. Anyone have any thoughts? I am stumped.
Thanks!!
1984 911 Targa
1986 911 Coupe
Old 01-03-2001, 08:32 AM
Superman
Guest
Posts: n/a
Alignment?
'83 SC
Old 01-03-2001, 08:34 AM
nhromyak@yahoo.com
Guest
Posts: n/a
Specifically, rear alignment...
Good luck
Nick
Old 01-03-2001, 11:36 AM
BRAINIAC
Guest
Posts: n/a
After checking all the suspension bushings and wheel bearings, you might check the motor and trans mounts. Mine was torque steering on me because the motor mounts were dead and allowing the engine and trans to twist, making the axles work at weird angles. (I assume) It seemed strange to me but it fixed it. Made shifting more precise and seemed to stiffen the car up as well. Just a thought. It sounds like my symptoms exactly, so I thought I'd share.
Tyson Schmidt
72 911 Cabriolet
Old 01-03-2001, 04:53 PM
Blizzard
Guest
Posts: n/a
Tyson,
Thanks, I have checked all the other areas, but not the motor mounts. I'll check it out. The car has only 43,000 miles on it, but it is 14 years old - I assume the mounts can get brittle.
Does anyone else have any experience with this problem? How do I check the rear end allignment?
Thanks everyone!!
Paul
1984 911 Targa
1986 911 Coupe
Old 01-04-2001, 02:15 AM
tstarke4
Guest
Posts: n/a
It does sound like you have a rear alignment problem. I highly recommend a 4 wheel alignment at a shop that is experienced with 911s.
Old 01-04-2001, 04:26 AM
