arbita1's Avatar
205's or 225's on the Front?
I'm moving my 7's from the rear to the front. My question is, should I put 205's or 225's on the front?
The car is used for 50% autox and 50% street.
And I don't want to have to roll the fenders.
I searched other posts and they just confused me more.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-13-2007, 05:11 PM
depends on the tire somewhat. I would say 205's on the front.
Most Porsche's perform better when there is less tire cantilever over the wheel lip. 225 will fit but might rub on hard cornering.
I run 225's on the front for normal street driving but go with 205 for the track where hard cornering is involved.
Tony G
2000 Boxster S
Old 03-13-2007, 05:24 PM
the the is offline
I'm a heretic, but I think 225s ruin the sublime steering feel of the 78-89 911s.
I'll take the 205 any day, at least for the street.
Old 03-13-2007, 05:25 PM
911 OCD
jpkelly3's Avatar
Can I ask a stupid question?
Why go to the trouble and expense of putting 7s on the front if your going to use the same tire?
Or are we, in fact using a different sized 205?
Is there less roll with a 7 v 6?
jk
82 SC Euro 82 SC Targa 69 912 62 AH 3000 97 740il
'If you are under control, you're going too slow'
Parnelli Jones
Old 03-13-2007, 05:44 PM
Registered Usurper
DARISC's Avatar
FWIW, I run 205/55 16 front, 245/45 16 rear on 82 SC my daily driver.
Had to roll the front fenders. The Yoko AVS ES100's that I reun perhaps have a heftier shoulder than some other brands, maybe this is why.
Alao, mine is RoW, lowered even a bit more yet. As a street car, I don't think I'd want to ruin the sublime steering feel with larger tires either.
'82 SC RoW coupe
Old 03-13-2007, 05:45 PM
Dueller's Avatar
DARISC, the....either of ya'll got the Pelican part number of that "sublime steering"?
Gotta get me some
Old 03-13-2007, 05:49 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
225 is too wide for the stock ront fenders and def too wide for the inner well
205 even hits sometimes
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 03-13-2007, 05:50 PM
ToddM's Avatar
205s already hit not only the fenders on occasion but the inside wheel well at full turn. 225s won't work
-Todd
Old 03-13-2007, 06:08 PM
arbita1's Avatar
Looks like I'll be putting on the 205's then.
The 205's on the 6" wheel will buldge over the sides more than on the 7" wheel. Thus making them stiffer on the wider wheel. Also, the 205 on the 7" wheel will be slightly wider than on the 6" wheel, even though the tire size doesn't change.
I usually like to put 205's on a 7" wheel, but since I have 245's on 9" wheels in the rear, thought the 205/245 combo would be too far apart and maybe too much understeer. So I thought the 225 would bring it closer together. But I don't want to roll my fenders, so I guess it's going to be the 205's.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-13-2007, 06:10 PM
RETIRED
Joe Bob's Avatar
7s and 8s....225/45 and 245/45 no roll, no rub....
2012 ML350 3.0 Turbo Diesel
Old 03-13-2007, 06:51 PM
FenderGuy's Avatar
I have 7 x 9 x 16 fuchs on my 911. I run 225 front and 245 rear. If i had to do over Id go with 205's in the front, for some reason I feel the steering feels heavy to me. I noticed that the drivers side front tire is getting eating up by the fender.....
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 03-13-2007, 07:21 PM
RETIRED
Joe Bob's Avatar
Soft shocks or high profile tires or bad alignment or a combination can cause the front fender to chew up the tire...
Old 03-13-2007, 07:24 PM
FenderGuy's Avatar
Mike Z my tires are 225/50 up front I thought that was night size for no rubbing, guess not. my rear shocks are brand new I have a feeling the fronts havent been replaced
Frank
Old 03-13-2007, 07:30 PM
RETIRED
Joe Bob's Avatar
Well I have a stock fendered SC, 7s with 225/45 slammed below euro height....no rubbing....
Old 03-13-2007, 07:56 PM
Registered Usurper
DARISC's Avatar
Hmmmmmm.
'82 SC RoW coupe
Old 03-13-2007, 09:01 PM
ToddM's Avatar
It wont rub if you never turn the steering wheel
Even with 22 front torsion and sway with HDs I have had a signifigant portion of the tire INSIDE the wheel well on a sharp corner and could not turn the wheel as much as I needed and almost ate it into a guard rail.
A lot of this has to do with how you drive.
-Todd
Old 03-13-2007, 10:04 PM
durn for'ner
livi's Avatar
My experience too.
Markus
Resident Fluffer
Carrera '85
Old 03-13-2007, 10:33 PM
