-   -   Running like crap after disuse (http://forums.pelicanparts.com/porsche-911-technical-forum/335607-running-like-crap-after-disuse.html)
widebody911 03-14-2007 10:37 AM
I haven't been driving my 911 much lately. I drove it to a show/swap back in October, and before that I hadn't driven it since July or so when I smogged it. As a result, it's all buggered up.
The primary symptom is a heavy miss anywhere past half-throttle. If I try to go WOT, it feels like the rev limiter is kicking in. When accelerating part-throttle, the new rev limiter kicks in around 5000 RPM, although it's not consistent. It's a little rough at idle as well.
Any suggestions apart from fresh gas (done) and techron (done)? I'm tempted to just replace the injectors outright, but I wonder if there could be something else funked up that I should look at. Plugs? They're not that old, and I didn't think that storage would foul them.
I haven't been to the track in over a year, and I signed up for an event on 4/16 @ Thunderhill. In an attempt to shake out some of the cobwebs, I drove it to work today. That's John Birkett's M491 parked next to me.
http://forums.pelicanparts.com/uploa...1173893725.jpg
DW SD 03-14-2007 11:07 AM
any chance your fuel filter is plugged? I had a similar problem with mine. I had fibers from the inside of the fuel cell plugging my filter (I added a filter prior to the fuel pump).
When it became more acute, my car would die for a few moments following a heavy application of throttle. The pump would have to catch up on the fuel pressure, I believe.
My filter is an Earl's. I cleaned the screen on two occassions and the problem went away immediately.
Techron would not have solved my problem.
Doug
randywebb 03-14-2007 11:18 AM
Thom - I was going to say plugs - but you already did.
I'd first "floor it!" - try some high speed running and see if it clears up - the Italian tune-up is often helpful and usually fun.
You can try it cruising right at 5k, then see if you can run it a little higher.
If not plugs (or do you have mech. points?), then it is time to think about what could have happened in storage - i.e. animals chewing on electrical wires, debris falling into the wrong hole, etc.
I had a similar issue and it was the plugs - they loaded up superfast on my carbed motor - twin-plugging notwithstanding.
Good Luck!
widebody911 03-15-2007 07:20 AM
On the drive home from work yesterday, the car improved significantly, although it's still maybe 75% of 'perfect'
I think I'll go ahead and order up a fuel filter and a set of plugs, just to be on the safe side.
nineoneone 03-15-2007 08:49 AM
I might check the distributor for moisture, as they set-up condensate may form under cap.
patkeefe 03-15-2007 09:01 AM
Moisture is my guess #1. My old farmer's adage of "90% of the time, it's a fuel delivery problem" doesn't apply well to 911's, I have come to find out.
Chuck Moreland 03-15-2007 03:46 PM
I go by the adage that most fuel problems are found in the ignition. After you've been through the ignition twice and ruled that out as a problem, go through it again to figure out what you missed.
That said, I would change the fuel filter.
bigchillcar 03-15-2007 03:52 PM
chuck +1
