Does anyone know if a Bosch SR 17 X starter will fit a 2.0?
I bought an SR17X starter as it claimed to fit a 2.0 but I don't know that to be true.
Old 03-15-2007, 07:23 AM
Friend of Warren
Should fit.
Kurt V
Old 03-15-2007, 08:04 AM
Early_S_Man's Avatar
Porsche Crest
It better fit, since that is the model starter it came with!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-15-2007, 08:42 AM
Ok good, my old one isn't broken but I got a rebuilt one so I figured I would swap it in. Is it a bear to install?
Old 03-15-2007, 04:40 PM
Porsche Crest
Easier than on a 915 ...
1. Put the rear end up on jack stands, and remove both rear wheels.
2. Get a high-quality 3/8" drive 10 mm Allen drive bit, and a 12" extension. A flex-head SK ratchet works best.
3. Clean the recess of the barrel nuts with Q-tips & solvent before attempting to insert the drive bit.
Warren Hall, Jr.
Old 03-15-2007, 06:45 PM
Shaun @ Tru6's Avatar
Are the 915 72-on starter motors OK for use on a 69E?
Tru6 Restoration & Design
Old 03-15-2007, 07:18 PM
Porsche Crest
Shaun,
Yes, the SR-17 and SR-68 starters are interchangeable.
Warren Hall, Jr.
Old 03-15-2007, 08:12 PM
Thanks Warren. I had heard that the 68s had a little more oomph to them. My last starter pinion stuck and ate away half my flywheel teeth. I will be buttoning back up soon, want to put the best motor back in.
Old 03-16-2007, 05:38 AM
