Broken Door Check Arm...Think it can be welded? (pic)
Seems this is not the typical place for the Door Check to break?
I had to grind the pin off in order to get the door to shut when it broke. -very glad that it broke at my Dad's place in Vermont where I had access to a grinder!- I really don't want to take the door panels etc...off again (did it last year) I'm not an experienced welder, so does anyone think it is possible to weld the arm back together? Or is there not enough access? too close to the rubber seals? TIA
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
Racer
Don't need to weld anything if that is the only damaged part. That piece bolts into the door and is replaceable.
Here's your part: 911-531-957-00-M260 Pelican sells them of course.
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
But if I can weld it, it will save me the trouble of taking off the door panel and $33...Or is it more trouble to weld?
it will probably just break again. you would need to grind off most of the weld to get it to slide properly. 1/2 hour and it's replaced with a new one.
Listen to John. Don't waste your time!
anything CAN be welded, but some things SHOULDN'T be. if it was an irreplaceable part then weld or fab new plate, in this case replacement is easy and cheap. just my canadian $.02 ( about $.018 US), so really practically worthless. Don.
Find something that you like about taking the door panel off, and think about that the whole time. You'd need to take it out to get a good weld all around it, and the sparks would damage the surrounding paint and rubber if you left it in anyway.
I'd go with a used door stay or switch the driver's side one to the passenger side, and put the new one on the driver's side (higher wear on the driver's side). But then, that means taking off two door panels.... |
I welded mine on my 77 Targa..BUT..I had door panel off, took out door check, spent about an hour grinding, welding, grinding again, filing, fitting,blah,blah,blah..Do what John and everyone else says, buy a new one. I did it because I love a challange and I am cheap...
OK OK...Will order the new part. Thanks for the feedback!
