-   -   Need a picture of Turbo twist wheels on 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/336171-need-picture-turbo-twist-wheels-911-a.html)
zbph10 03-17-2007 11:55 AM
Does anyone have a picture of a 911 with turbo twists on it?
Thinking about getting a second set of rims around for my 87 and I'm thinking cups or turbo twists. Would be open to other options as well.
Brian
jpc1818 03-17-2007 12:05 PM
how about this!!!!
before
http://forums.pelicanparts.com/uploa...1174161710.jpg
After
http://forums.pelicanparts.com/uploa...1174161808.jpg
http://forums.pelicanparts.com/uploa...1174161938.jpg
Garrison 03-17-2007 12:16 PM
Here is a picture of my car with Turbo Twists on it.
http://forums.pelicanparts.com/uploa...1174162465.jpg
Dueller 03-17-2007 12:31 PM
Red
http://forums.pelicanparts.com/uploa...1174162539.jpg
yngwie1 03-17-2007 01:06 PM
Those look nice. I have my original Fuchs still, but have to admit that these look nice. Do they fit on without modification on say an '87 911 or what?
Thanks,
Patrick
Dueller 03-17-2007 01:30 PM
Personally I like the cups better than the twists...but the twists were available cheap and I wanted to get more meat on the ground.
Real cups or twists require a 1 1/2 adapter on the rear and a 1 inch on the fronts. There are some aftermarket cup I's available in sc/Carrera offset but they are pretty heavy.
Cdnone1 03-17-2007 01:37 PM
Here they are on a 89 cab
http://forums.pelicanparts.com/uploa...1174167437.jpg
steve
Doug&Julie 03-17-2007 01:51 PM
Keep in mind you're seeing two examples of cars with Turbo Twists and two examples of cars with Boxster twists. Personally, I like the Boxster twist wheels because they have some curve to their profile, where the Turbo Twists are very flat. Just my opin, of course. :)
Jack Olsen 03-17-2007 01:59 PM
You need spacers (with much longer studs) or adapters (with their second set of studs) to run the later-offset wheels, which would make switching back to the Fuchs a fairly complicated endeavor. If you want to switch two wheel sets back and forth, you'll be happier if you get wheels with the same offset.
zbph10 03-17-2007 03:17 PM
Thanks for the pictures, the spacer issue is something that has always confused me. I've read a lot of posts in regards to them and still do not really understand what I need.
If I understand correctly the aftermarket wheels have a different offset that probably would not require spacers and late model OEM wheels require them?
What offset we talking about? The distance measured from the back side of the rim to the face that mounts to the rotor? I have no idea what I'm talking about.
Anyone have a picture of a spacer mounted to the rotor? Might help me understand what they do and how they work.
Thanks guys
Brian
Joe Bob 03-17-2007 04:28 PM
Typically, one inch up front and two in the rear will allow for the use of many late offset on an SC or a Carrera. At least that's what the late 16x7 and 16x9 off of a 964 took for MY SC.
84Euro 03-17-2007 05:43 PM
http://forums.pelicanparts.com/uploa...1174181941.jpg http://forums.pelicanparts.com/uploa...1174182077.jpg
RarlyL8 03-17-2007 05:50 PM
Here is a picture of adapters bolted to a hub.
http://forums.pelicanparts.com/uploa...1174182482.jpg
84Euro 03-17-2007 06:35 PM
http://forums.pelicanparts.com/uploa...1174185234.jpg
Another view, rear
unclebilly 03-23-2007 07:23 PM
I want to chime in on this.
I have 17" ROH's on my 77 widebody and just bought 18" Turbo Twists for it (They are at the shop awaiting rubber). The 17's are installed with spacers and work OK.
When I aquired my 71 Tub (with rear suspension), I bolted the rear wheels from my 17 on to it to wheel it around and it worked OK - no spacers. Agreed, the suspension was at max travel (no motor) but I was surprised that they wouldfit under the rear fenders.
Comments?
Danny_Ocean 03-23-2007 09:56 PM
Not to hi-jack the thread, but...does anyone know if the TurboTwists are directional? Looking at the above pics, I'd say yes, but I've seen pics of other cars with one side having the wheels "backwards".
http://forums.pelicanparts.com/uploa...1125449059.jpg
I'd love to get a set, but only if directional...
unclebilly 03-23-2007 10:06 PM
nope. not directional. the ones above that are must be the boxster wheels.
dugsud 03-24-2007 04:30 AM
I've gone the opposite way from original teledials to twists and now Fuchs. The pictures below span about four years the oldest at the top.
What about wide Fuchs instead of the cups, perhaps 9"s on the back?
http://i55.photobucket.com/albums/g1...hanging911.jpg
strupgolf 03-24-2007 04:40 AM
Here's pic of my 86 with TT's. I have to run adapters on it. These came off a 996. http://forums.pelicanparts.com/uploa...1174740033.jpg
MattAlpha 03-24-2007 06:01 AM
Guys here are my 993 turbo twists on my 911.
http://forums.pelicanparts.com/uploa...1174744891.jpg
I have a hub adapter on the rear just like Rarly8's. A bit of warning though, I just got back from a first rate shop (Performance Art) and their Porsche tech (with over 35 years experience) told me that adapter set-up is a safety concern on a driven axel. He told me that you need to go with a plain spacer and longer studs. I just wanted to mention that.
-Matt
