What are these parts??
I am doing a a little 2.7 rebuild and figure everything that comes off should get a new gasket. Also if you guys know on this 1976 S motor what color wires go to each of these.
Nathan
1=?
2=?
3=?
4=?
5=?
6=?
1981 Delorean
Old 03-15-2007, 10:48 AM
Pingo's Avatar
1 . Crank case breather cover
2.
3. Oil pressure switch??
4.
5. Oil pressure transmitter
6. Temprature sensor???
Old 03-15-2007, 10:56 AM
DP935 member
kycarguy 935's Avatar
2. Oil Thermostat
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 03-15-2007, 12:08 PM
#4 Thermal time switch - mounts on the left rear of the engine.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 03-15-2007, 12:26 PM
Thankyou again Walter for your knowledge. I want to make sure I am getting all the right gaskets for any of the items I can. I took off the cam covers today to reveal the chain tensioners having those safety things on them, and the oil tubes on the bottom of the motor, the O rings were dryed up and broke. That cant be good. It looks like as well as the O rings there are other thicker gaskets and there was also a lot of silicone stuff around the area.
Nathan
1981 Delorean
Old 03-15-2007, 12:48 PM
Nathan,
To finish answering your questions about the wire color:
#3 = oil pressure switch = green/white
#4 = Thermo time switch = yellow on one side and red/black on the other. The yellow wire is supposed to be combined with a grey/white wire, but mine combines with the yellow wire inside the wiring harness - not at the switch.
#5 = oil pressure = green/red
#6 = oil temp = black/green
Rex
Old 03-15-2007, 04:33 PM
Early_S_Man's Avatar
Nathan,
It is important to note that your pic shows chain wheel carriers were not updated to the 1980.5+ style with double bushings ... this is a very, very important issue! The double-bushing chain wheel carriers are considered to be the 'real' fix to all tensioner failure remedies that were tried by the factory from 1966 - 1984!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-17-2007, 09:00 AM
Somatic Negative Optimist
Gunter's Avatar
Nathan:
Give us a picture of both chain housings showing the entire chain so we can tell you if your chains have stretched.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-17-2007, 11:05 AM
Here is a pic of both. Also I have removed the collapsable oil tubed and small O rings were dry and broken and notice the massive amount of silicone around the green larger o rings
Thankyou for all of your help.
Nathan
1981 Delorean
Old 03-17-2007, 01:58 PM
Gunter's Avatar
Looks to me the chains still have some life left.
There is nothing wrong with mechanical tensioners as long as they are rotating freely on the shaft plus you have the safety clamps.
It's your decision: Upgrade to hydraulic tensioners or keep what you have but check that they don't seize.
I had the same oil tubes and couldn't find new O-rings.
If you split the case anyway, use the non-collapsable tubes.
Have fun.
Old 03-18-2007, 08:19 AM
