-   -   Trouble removing rear seats (http://forums.pelicanparts.com/porsche-911-technical-forum/336326-trouble-removing-rear-seats.html)
lfot 03-18-2007 11:27 AM
Am I missing something? I'm trying to remove my rear seats, and I seem to be stuck (or the bolts are stuck) on unscrewing the slotted bolts at the hinge points. Is there something I'm missing here, or are they just stuck? Also, what do you do about the pins in the middle hinge joints?
jester911 03-18-2007 11:36 AM
Use the biggest flat screw driver you have and an adjustable wrench to break them loose. They just need a little leverage.
group911@aol.co 03-18-2007 12:38 PM
They are just stuck! The last few I've removed, I had to use an impact screwdriver. An inexpensive tool that you strike with a hammer that brakes the bolts loose.
lfot 03-18-2007 12:59 PM
Thanks. I also so a thread where someone mentioned "soaking" it. Soaking it in what?
toddu 03-18-2007 01:20 PM
Probably some form of anit-seize, or "break free" solvant (liquid wrench for example, better products available). Just be careful as this stuff typically has a VERY strong order to it, so if you get it on your carpet, etc., it's gonna stink.
randywebb 03-18-2007 03:18 PM
pb Blaster or Kroil are good for the soaking -- they need you to tap the fastener dozens of times and they need TIME to work - 2 days or so... tapping all the while
next try a prybar and/or the manual impact driver noted above
after that rip the upholstery off with your teeth and use a torch to burn it all up while applying as much heat as you can to the fasteners
last, you can try C-4
Do these steps in order, do not skip steps...
Formerly Steve Wilkinson 03-18-2007 04:16 PM
I think those bolts basically get stuck in place by some kind of intrusion into the threads from whatever is sprayed on as underbody sealant. That's what the penetrant unseals--not rust but the undercoating.
