twobone's Avatar
installing a rennline strut brace
Re:
2 Point Strut Brace - Rennline strut tower braces bolt in and out in minutes and require no drilling.
Before I do something stupid.
The mounting plates have two bolt holes. Are those for the two rear bolts?
Once it is on, do I tension it with a lot of force or just take out the slack?
Any special install tips.
Old 07-07-2005, 05:42 PM
jtkkz's Avatar
Smile
I installed one of this on my '71 911T
The rear 2 bolts are the ones you use.
I just took the slack off plus a bit more
maybe an expert can jump in and tell us exactly how tight to tension it.
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 07-07-2005, 05:47 PM
twobone's Avatar
If I'm only taking out the two bolts, I don't have to worry about alignment, right?
Old 07-07-2005, 06:20 PM
Adrenaline Junkie
Hayabusa's Avatar
Who did you order that through? How much?
Old 07-07-2005, 06:24 PM
twobone's Avatar
through Pelican $176.75
Old 07-07-2005, 06:28 PM
twobone's Avatar
Old 07-08-2005, 05:52 AM
steve911's Avatar
I went with the Elephant 2-point brace and did not have to worry about the alignment. Chuck's instructions were to tighten a 1/4 turn. You might check with Pelican or Rennline - seems there should be some installation instructions for it.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 07-08-2005, 06:48 AM
if your only taking out to two bolts you don't have to worry about alignment but while tey're out don't jar the car around or sit in it as you alignment is only being held by the one bolt.
getting the jump on my mid-life crisis
Old 03-24-2007, 09:28 PM
