Stainless Steel Braided Lines
Does any body have a good source to have stainless steel braided hoses custom manufactured? I need for fuel and oil lines on a turbo.
I know of Aeroquip - Any others? Thanks |
Pre Registered
Mo money = mo parts
It wasn't clear if you meant custom-made for you or custom-made by you. I just bought fuel lines from these guys, as have many other on the board. They have a complete Mocal Oil Cooling guide for Porsche, metric fittings, lots of good stuff.
British American Transfer
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Thanks for the input. Went to the BAT website - me likey - especially the titanium connectors. Well I guess its time to start measuring and open up the wallet. This is going on my 78 - 930. I have a thread posted "930 renovation" if anyone is interested. Right now I am just working on updating the fuel injection and new spark plug wires for the twin plug crankfire. So braided lines seemed like the next step. In the next few days, I am going to post more picts of the powder coated and polished parts. T
There has to be a point when I have to stop. Too much "while I am in there" thinking. Thanks again |
never gonna happen
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
1966 - 912 - SOLD
it is finaly nice to see black hardwear instead of the tacky red and blue stuff
Try Swedgelok
12251 Cary Circle Suite 500 La Vista, NE 68128 402-733-7636
'78 Targa Sold! '84 Carrera Sold! '01 996 Wrecked |
mrm930, The braided lines with AN fittings are easy enough to make as long as you have a few "basic" tools. I use a bench vise along with a set of the aluminum soft "jaws" to hold the fitting during assembly. You can also purchase the fancy aluminum fitting wrenches, but I find wrapping the fitting with masking or electrical tape & using an an adjustable wrench in conjunction with the bench vise/soft jaws works just fine. Also, I cut the braided line with an air grinder with a cut off wheel. Wrap the hose with masking or electrical tape prior to cutting so the braid does not fray.
Make sure you thoroughly clean out the lines with air, water & air before attaching the fittings & after fittings are attached. Oil the fitting threads prior to assembly & they go together like a knife through hot butter. I've plumbed a couple of SCCA GT race cars & my current weekend driver 911 using this method & have never had a fitting assembly failure. Jegs & BAT are good sources for the parts you will need. Here's a photo of some recent braided lines, albeit the "tacky" blue & red fittings, on the weekend driver. Regardless of the fitting color I think this is just so much nicer looking than cheesy hose clamps & that nasty factory cloth braided hose. Porsche purists my want to look the other direction, since I prefer a touch of "hot rod' as opposed to bone stock! ![]()
Decided I should do those from the exit of tunnel to pump and from pump forward due to age and (while you're in there) however I will do these in a different material as the braided stainless can chafe other cables, lines etc.. will probably use the Lightweight or Starlite hose for these. Paul
RGruppe #180 So many cars.. so little time!! Last edited by onboost; 03-23-2010 at 12:46 PM.. |
Paul, How did you connect & convert to AN fitting from your factory hardlines at the exit of the tunnel? Did you use one of these?
I haven't gotten to that point yet.. but the thought is to use something similar, or I may use/incoprate the factory hardware to that area.
RGruppe #180 So many cars.. so little time!! |
m1franck - very good look. Mine will be similar. I'm jealous - a carbon fiber engine shroud!. Looks great.
onboost - Did you eliminate the hardlines at the fuel accumulator and fuel distributor and go with all braided lines? - or - Did you incorporate hardlines and braided lines?
This is what I want to start with and go with the oil return lines like in the photo of m1franck - along with others. And m1 - I am going to fabricate them myself - sounds like you got it down. Mark |
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
'74 Euro Carrera * '64 356SC Coupe |
Agreed. Is that a carbon fiber fuse cover on the left?
Yes, that is a CF fuse panel cover from AutobahnExtremist: Autobahn Extremist
It's very nicely done & a great piece of engine compartment bling. |
I know everyone knows this, but as a reminder S.S. braided lines will eat through other surfaces if they're not clamped up properly. I've had them rub right through aluminum aircraft baffles and cowlings when they were not tied down.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
As Mitch stated, you need to be sure that they are tied back ast not rub anything. Braided stainles is capable of chaffing through other lines, cables, and other metal and aluminum surfaces if not properly isolated. That was the reason for suggesting the lightweight or Starlite hose Anyway, these lines are from another project, non-Turbo. However, they are braided stainless and are set up to mate to the factory hardlines at the exit of the tunnel using the factory fittings.
RGruppe #180 So many cars.. so little time!! Last edited by onboost; 03-28-2010 at 10:23 AM.. |
