Hatari
Guest
Posts: n/a
72' 911 shocks - OEM manufacturer
Is there an easy way to tell which manufacturer's shocks are on my 72' 911T. The current rear set is red-orange in color...Koni? The fronts are black. I do need new ones and from what I've read, they could be one of 3 manufacturers. I can't find any remaining decals/labels.
Thanks...
Jack McAllister
Old 01-08-2001, 06:33 PM
rstoll
Guest
Posts: n/a
Black ones may be Boge.
Robert Stoll
83 SC
83 944
Old 01-08-2001, 06:45 PM
BRAINIAC
Guest
Posts: n/a
Oops, wrong reply.
Tyson Schmidt
72 911 Cabriolet
[This message has been edited by BRAINIAC (edited 01-08-2001).]
Old 01-08-2001, 07:31 PM
JackOlsen
Guest
Posts: n/a
Uh, Tyson?
Jack Olsen
1973 911 T (3.6) sunroof coupe
Old 01-08-2001, 07:41 PM
BRAINIAC
Guest
Posts: n/a
Yeah, Jack?
Tyson Schmidt
72 911 Cabriolet
Old 01-08-2001, 08:16 PM
BRAINIAC
Guest
Posts: n/a
The black struts would indicate that it either came with Sachs or boge. However, since the rears are Koni, it may now have Koni inserts inside the Boge strut housings. Are there little flat things that look like the tip of a screwdriver sticking out of the top of the threaded shaft? (In the front trunk on top of the strut). If so it has Koni inserts.
Tyson Schmidt
72 911 Cabriolet
Old 01-08-2001, 08:23 PM
JackOlsen
Guest
Posts: n/a
Tyson,
I had seen the dash fix response -- but you pulled it.
Jack Olsen
Old 01-08-2001, 08:49 PM
BRAINIAC
Guest
Posts: n/a
OK now it makes sense Jack. I got a little confused and answered the 930 question on this post. I should switch to decaf.
Tyson Schmidt
72 911 Cabriolet
Old 01-08-2001, 08:53 PM
