xtianw
Guest
Posts: n/a
Changing/ Upgrading fuel lines
I have just finished resealing my fuel tank and am in the process of refurbishing the trunk area. While the tank is out I thought it might be a good time to replace the factory fuel lines as they are 32 years old.How difficult a job is this? Where do the fuel lines travel in the car? Any input is appreciated. Thanks
CM Wagner
1968 911 S Coupe
Light Ivory
Old 01-08-2001, 04:26 PM
ClayMcguill
Guest
Posts: n/a
The fuel line travels through the central tunnel, under the shifter and E-brake. You can order a loop of aluminum tubing from Jeg's or Summit Racing for about $20 and bend it easily by hand into whatever shape you need.
Clay Mcguill www.geocities.com/the912guy
[This message has been edited by ClayMcguill (edited 01-08-2001).]
Old 01-08-2001, 09:15 PM
