911nutcase
Guest
Posts: n/a
Brake Pads, Front
Just changed the front brake pads......and the braking feels soft when I start the car up.....when I turn the key, with the car off, the brakes feel a bit more stiff....
is this normal...I checked for leaks, found none, I checked the level in the master cyliner....fine....
help
Old 01-08-2001, 07:56 PM
BRAINIAC
Guest
Posts: n/a
Did a portion of the rubber boot around the caliper piston get wedged between the piston and pad? Also, if you didn't turn/replace the rotors, they won't feel right until the pads wear to the shape of the worn rotors.
Tyson Schmidt
72 911 Cabriolet
Old 01-08-2001, 09:33 PM
