sensor distance
Dear
I have a 3.2 engine from 1987. Does anyone know how much the distance should be in "mm" between flywheel en speed sensor (there are 2 sensors located right next to the flywheel; it's the lowest sensor) Regards Porscheke |
.08mm should be good.
Do you mean 0.08mm ???
That is very close? |
.08mm is 0.003" hmmm. Maybe he meant 0.8 mm which is 0.032 in American.
So should it be 0.8 mm ???
31 thou, that would be .8mm sorry its early here...
I really just took this out of the book, I was going to give it to you in inches but noted you wanted mm, its printed in the book as .08 which is not correct, the scary part is I just did my own taxes this year :eek: |
Ok
thanks !! |
| All times are GMT -8. The time now is 09:04 AM. |
