Rear 930 rotor on to the 1970 original hub?
Hi
I am working on my project car. 1970 rs body kit, 3.2, G-50 and a set of 930 brake. The front caliper and rotor are bolt on with the VCI hat. The rear calipers are already remachine for the new mounting spot BUT How can I mount the rear 930 rotor on to the 1970 original hub? Do I need to use a set of aluminum trailing arm? Thanks Burint Bangkok, Thailand
