83 Euro SC Start Intermittent
I really need help here:
Problem: all of a sudden popped, my 911 "sometimes":
1. starts OK
2. starter clicks - does NOT turn engine, or
3. now, no starter click
Findings and done so far:
a. battery checked 12.48V with nothing running, when engine running 13.78v (alternator good). Headlight dims when ignition turn to start.
b. just replaced the Ignition Switch - Electrical Portion today - thought this is the culprit.
c. changed starter to hi torq 4 weeks ago, shotgun troubleshooting that cost me $150 - problem started even before this starter was installed.
d. Fuel pump replaced 3 weeks ago - another victim of shotgun T/S
e. Fuel pump relay replaced $15
f. Body ground wire on tranny & body checked. As well, Negative post ground - good connection on both.
g. Seems like every time I disconnect an electrical component i.e. battery post, the ignition switch electrical it starts right off - not all the time though.
h. 'sometimes' it starts oK - cold or hot.
i. checked AAV - plunger plate on half moon and not stuck. No hammer tapping on this one.
Calling all Porsche 911 Gurus: given the above, what is the problem with my car?
83 zzz Targa G. Red
79 Coupe 27K mi 959 Red
88 Fiero 9K mi Red
88 Fiero 30K mi Ylw ttop
88 Mera 28K mi Red
93 40th Corvette
75 Corvette
Old 03-21-2007, 07:53 PM
