How to draw a frustrum?
I want to have a 3" steel tube pass through sheet metal at a shallow angle, maybe 10-20 degrees. I'm going to weld the tube in place around the whole tube so as not to loose much of the sheet metal's structural value. To do this I need to make a template of the cut I will have to make in the sheet metal so it will but up against the tube before I start welding.
Attached is my guess at the formula for this. I cut this figure out of a piece of paper, and it looked like it worked for a 45 degree angle as shown. Though the ends look a little pointy and weren't quite as good a fit as the rest seemed to be. I suppose I could do this with cardboard and get a better idea of whether I am on the right track. And news flash - that would be the cotangent (or 1 over the tangent), not the tangent, if I am on the right track: two otherwise ordinary intersecting arcs one diameter apart in the middle. http://forums.pelicanparts.com/uploa...1174636195.jpg Or does a diagonal slice through a cylinder create an ellipse or some kind of parabola or paraboloid? If so, any tips on how to draw the template? This is going to make my brake ducting abrasion proof, or so I hope. Walt Fricke |
Not quite related but close. You can get a tube mitre software program here http://www.tonyfoale.com/ . Click on the freeware link and go to "Tube porfile cutting guide" .
I quote from the instructions: "You can input sizes of two round tubes that you wish to join together by notching one of them, the programme will then allow you to print a paper template which can be wrapped around the tube as a guide to cut the right shape. It will handle tube sizes of up to about 80 mm. diam. This limit is set by the size of the paper in your printer. This programme has no use unless you are actually constructing a tubular structure." Regards Johan |
Here's what I'm getting on the Mac, by starting with your circle, skewing a copy of it 45 degrees, centering everything, then creating an elipse that picks up all the outer points. We do stuff like this in the shop (sign fabrication) and that's the method I use. No guarantee, but it might be worth cutting a template and seeing if it fits. The "fabricator's trick" above should produce the same shape. BTW, this shape should work for any tubing diameter @ 45 degrees, by enlarging/reducing so that the vertical dimension = tubing diameter.
http://forums.pelicanparts.com/uploa...1174657651.jpg |
For the record, the shape is an ellipse w/ a minor axis = the diameter of the tube. The length of the major axis is determined by the angle between the plane surface and the tube axis.
If the tube mitre program doesn't work you can always use a flashlight, the shape of the pattern on the plane surface is a circle when the angle of incidence is 90° and transforms into the ellipse that you want as this angle is changed. The size of course should be determined by the length of the minor axis. |
Bill,
I suspect the flashlight trick works if the beam is focused and not diverging, otherwise you would get a pattern for a cone. I like the 'cut a piece of tubing at that angle and use it as a template' method. Les |
Old trick is to place 2 pins in a piece of paper 1/3 the diameter of the tube in question apart.
Then cut a piece of string and tie the ends together so that it is the diameter of the tube. Place the string on the paper (flat) and put your pencil in the circle of the string. Start drawing the line by pulling the string tight against the pins and continue in a circle. You will end up with an elipse. If the dimentions are correct, the one direction will be the diameter of the pipe, and the other will be the extended elipse. Old style way of fabrication. (just realised that I am showing my age...lol) Bob |
LOL, Bob - Are you a former sign painter? That's the way we used to draw elipses. Now we use the Mac for everything.
I have used the 2-points spread apart method for creating elliptical arches in construction many times. I've never had a formula for the distance between the two points. It's always been a matter of trial and error. I'll try to understand what Bill said. :confused: |
Here's another way to draw an elipse, similar to the "string" method, but creating points instead. Pulled this out of an old sign painter's book, which I haven't looked at in at least 15 years!
But really, all this method does is create the same thing that you can make on your Mac or PC. Even the most simple graphics software will have an elipse tool. Just draw a box that represents the height and width of the elipse, then draw an elipse to fit within it. In the drawing above, I just drew a circle, then "skewed" a clone of it 45 degrees, thereby establishing the height and width for the elipse. Try it - it's extremely simple. If you were going through a plane on a 30 degree angle, you'd just skew the circle 30 degrees to get the width, etc. etc. Then - that pattern will work for ANY diameter tubing, at that angle, by enlarging or reducing to get the height of the elipse to equal the tubing diameter. |
I may be wrong but it seems to me that most of the responses are missing the main point.
Assuming 2.5" tube, at an angle of 20° to the plane surface. He needs to be able to describe the unique ellipse that has a minor diameter of 2.5". The hard part is determining the ellipse that is defined by the angle. the standard 2 foci method w/ a string doesn't work because he doesn't know where the foci belong other than somewhere on the major axis equidistant from the intersection of the major and minor axis yes, the flashlight needs to have a nice focused beam but again assuming a minor axis < ~3" the parallax error will be small |
Why not make a carboard template through trial and error? How many iterations could it take?
Seems like if you can only narrow your angle down to 10 to 20 degrees, it may be an iterative process anyways? Good luck, Doug |
I did this a couple of months ago but you could try plugging the lower equation into XL.
0 < theta <2 pi z = 0 (since you want the x-y plane p = radius of the pipe phi = angle the pipe makes with horizontal (? not sure of Greek alphabet) vary theata from 0 to 2*pi http://forums.pelicanparts.com/uploa...1174667249.jpg here is what was in the XL cells but unfortunately I named everything. sin_phi and cos_phi are the value stored in a cell x =p_rad*COS(theta2) y =p_rad*cos_phi*SIN(theta2)+(Zhgt+p_rad*sin_phi*SIN (theta2))/cos_phi*sin_phi below is 60 deg http://forums.pelicanparts.com/uploa...1174667579.jpg |
Wow- what a great mix of old-timey and new, high-tech techniques.
Here's another http://vatsaas.org/rtv/tools/computationtools.aspx#transition But I'd try the flashlight first. Strong halogen beam held as far as possible - definitely not an LED type. |
I can draw an ellipse in 2 seconds in autocad, and print it so that a template can be made. I'd be happy to send a PDF of the drawing if that would be of help.
-Scott |
While calculating to get the shape of the ellipse might be fun and a challenge. If the panel is slightly irregularly shaped, or the tube passes through the panel skewed in more than one axis things could get interesting.
These tools are really handy to have around. they make fit up of tubing a breeze. Unfortunately the 3" pipemaster is $105... tough nut to swallow for a infrequently used tool. We have 1-1/2",1-1/4", and 1" at the shop. http://www.pipemastertools.com/ http://forums.pelicanparts.com/uploa...1174683233.jpg http://forums.pelicanparts.com/uploa...1174683248.jpg |
Thanks, guys. I was correct in assuming that a lot of us love a challenge.
RS9 - My first thought, too, was just to cut a pipe. However, I doubt my ability to cut a 3" pipe at a fairly acute angle accurately, so I want to hold that one in reserve. For those more adept or with better tools that certainly would make it easy. Flattop - I'm saving that site for when I fabricate a new roll cage. I haven't tried it using a nearly infinite radius for the second tube. Wavey and others with computer skills (mine being quite primitive) - I don't think I have a program that will do this, but may see if I do. Especially one that says it will put an ellipse inside a box, as I think I now know how to figure the box. And thanks for the trammel method - that's cool, and may be easier than the string method for my purposes. The cut with my hand jig saw in the sheet metal is probably going to be more irregular than a quick trammel pattern. I confess to being in the generation of all who mentioned the string method for an ellipse. Remembered it from high school, though not the details. This plus Google refreshed me. Bill V: By knowing the figure is an ellipse, I think I have it. I know the minor diameter. As you say, how do I correlate the major diameter with the angle, given the minor? How about this: Major diameter = minor diameter/sin phi (or however you want to denominate the angle). Derivation later in the post. Rick - you have your Greek right, but do I have my math right? I like the flashlight notion. Maybe a laser pointer rotated around a tube fixed in place? Another one I had thought of was to use a rod held parallel to the tube axis on its OD as a scribe. Plus I may want to punch through lower down where I am going through the somewhat complex sheet metal box tubing of the unibody just in front of where the front sway bar drop link is. The relatively flat sheet metal is a bit high up. Using light or a rod ought to allow me to scribe on irregular surfaces as well as part of the simpler vertical. Thinking of doing this is what made me get some fairly thick wall muffler tubing, thinking I could minimize the weakening of the unibody structure in this area. Googling around led me to www.cleavebooks.co.uk/scol/callipse.htm. That is an ellipse calculator. Enter the major and minor diameters and it gives you the foci and string length also. FYall's I, if I have things right, an angle of 5 degrees gives a major diameter of 38 some inches. Scratch that one. 15 is 12.85, and 30 is 6.6 inches, so I now have something to play around with for a reality check before I start cutting. The good news is that if I start at a larger angle, and that causes problems, every point for a smaller angle is outside the first cut (except right at the minor axis), as Wavey's diagrams show. DW - this may be my iteration: The practical problem is that this part of the front fenderwell area is a tight fit. I am using 3" hose, which doesn't help. In the past I ran it flush with the fenderwell, and where my slicks rubbed on it I armored it so they wouldn't rub through, at least not quickly. The reduction in turning radius was inconsequential for racing. But I don't know the max angle that will clear everything. I think I may start with 30 degrees and get smaller. I may have to cut some sections of a tube anyway unless I want to cut first and measure later, so to speak - but wait: I can just cut some scrap sheet or cardboard rectangles 3" across at various angles and use those. Two dimensions should work fine for this clearance checking. Scott - I may want to take you up on your offer of autocad and a PDF. Let's see how I do with cruder methods. Rick - I had forgotten that Excel offers charting/diagramming. But I think it would take me longer to learn to do that than the string or trammel methods would take. Excel frustrates me because I use it infrequently, so I forget many of the conventions/commands in between. For instance, I take Club Race registration lists (done alphabetically by driver, but including car number, color, type, and class as well), and sort by car number (what a scrutineer needs when told to find a car by number). Always have trouble getting all the columns to sort together, rather than just the car number one. OK, for the piece de resistance (hope pride doesn't go before the fall again): Here is how I derived the new formula for major diameter: Draw two parallel lines representing the diameter D of the tube/cylinder/unique case of a cone (as the mathematicians like to see a cylinder). Draw a diagonal line representing the angle to the plane through these two lines. From either of the two intersections so created, erect a perpendicular to the other line. You now have one side of a right triangle D, and the opposite angle phi, which is your intersecting angle. The major axis should be the hypotenuse. Pulling out my cheat sheet on trig, opposite over hypotenuse = sine of angle. Maybe this is embedded into Rick's more complete formula, which I bet includes the formula to find foci or otherwise describe an ellipse knowing major and minor axes? Thinking about this, it may only work if the plane (cut) is parallel to the minor diameter? I hope that is good enough for my purposes, as I hope to be able to angle the tube to the rear only, and not down as well (starting inside the body, in the direction of the air flowing). But maybe if I need a down angle as well, perhaps all I need to do is figure out how to angle the template down at one end when applying it? This thinking in three dimensions is tricky. Again, thanks, guys. I hope you had some fun shaking the cobwebs on a Friday morning. I sure did. Walt |
PS:
Tim - I had seen those nifty variations on the single plane body shape tool. And the price! I might buy the one for inch and a half if I ever get to making my own cage (plan - bend and cut and fishmouth everything, tack weld, and take to real welder to finish). And the URL I gave doesn't work, but if you chop off some of the end you will get to the site that lists their various calculators. Walt |
it's just a circular profile (aka contour) gage... neat idea but way overpriced.
how is this?
When making fishmouths and fitting tubing the pipemaster really cuts down on trial and error fit up, wasted pipe...waste time I bought 3 of those tools....and they have saved me hours of time (money)... |
For instance, a 90* weld will call for 2 equal 45* cuts. A 30* weld will call for a larger 30* cut and a smaller bite at 60* on the other side, more or less inversely proportionate to the angle of the weld. IOW, a deeper 30* cut of about 2/3rds more than the 60* cut. YMMV. |
you guys realize that the Greeks figured this out over 2,000 years ago...
Wrap and tape a piece of thin pattern paper around the tube you want to pass thru the panel. Slide the paper "tube" down the real tube and trim the paper to get the angle you need. Trace around the paper onto the panel and cut your hole. |
My method is to cut a pipe slice or make a dummy from cardboard by wrapping it around the tube, taping with masking tape to firm it up, cutting to shape and tracing the hole from the inside of the little cardboard dummy
I have found that many times this is the best way for me as I can fit test and adjust as needed. For some reason calculations are ether right or way off. Simple systems work. Dirty trick when welding a tube through sheet metal. drill the hole right where you want the center of the tube to be and stick a section of tube through the hole. Bend the sheet metal to conform to the tube angle using the tube as a former. Make little slits in the sheet metal if the angle is high and cut some if needed as well to keep from deforming the fire wall too much. After you have the tube in place you have nice little sheet metal flanges on each side to weld the the tube to. I too have the expensive Tube Masters. They stay in the box until I have a hard or compound cut to make then they pay for themselves when you make the last fish on a compounud bend tube you just spent 2 hours tweaking to fit just right and did not just cut the tube too short. Anyone that has made up enough tubing has done that at some point and it is a royal b!tch as it only happens when you are short of time or that type tubing to make a replacement. :mad: I used to hand cut tube but sprung for another expensive toy. It is nice to make compound cuts in one trip across the shop. They can get busy sometimes. http://forums.pelicanparts.com/uploa...1174725408.jpg http://forums.pelicanparts.com/uploa...1174725979.jpg |
Getting back to the original question -
This is really simple: a straight cut on an angle through round tubing creates an elipse that is specific to that angle. No complicated math or guesswork required. Any simple graphics or CAD program can draw the elipse. I'm posting the patterns for some typical angles, for 2" tubing, as a jpg. Anyone should be able to copy this to their desktop and print it. Directions for enlarging or reducing to your tubing size are included. I can also e-mail as a pdf if anyone needs that, or provide any other file type. Hope this is helpful! http://forums.pelicanparts.com/uploa...1174919370.jpg |
You need trig(or software that knows trig) to quantitatively analyse the dimensions of the ellipse wanted here. simplest formula for finding the major axis would be (diameter of the tube)/(sin(angle between the plane and tube)) the minor axis dimension of course is always = (the diameter of the tube) |
| All times are GMT -8. The time now is 12:00 PM. |
