-   -   slide a/c compressor? (http://forums.pelicanparts.com/porsche-911-technical-forum/337421-slide-c-compressor.html)
Pat Crellin 03-24-2007 06:48 AM
Trying to change my belt. I've loosened 4 bolts on the a/c compressor mount, should slide. What am I missing?
Pat Crellin 03-24-2007 06:50 AM
It's the fan belt I'm trying to change
Por_sha911 03-24-2007 06:14 PM
Did you loosen the bolts with the blue or yellow arrows? http://forums.pelicanparts.com/uploa...1174785222.jpg
Pat Crellin 03-24-2007 06:20 PM
Yes, there's 2 more behind the yellow arrows, right?
Was playing with the adjustment screw on the right but it didn't seem to move the compressor. It's been a while but I thought with those blue & yellow loose it should slide in. Nice looking engine.
Por_sha911 03-24-2007 06:25 PM
You should loosen the 4 yellow and the adjustment screw (not the 4 blue).
Pat Crellin 03-24-2007 06:35 PM
Is it safe to get a bar in there? Seems the belt tension should pull it towards the engine.
Pat Crellin 03-24-2007 06:36 PM
Joe , what do you have covering the nut on the fan pulley?
Por_sha911 03-24-2007 07:56 PM
With the proper bolts loosened the unit should slide. Get a bar in where?
The nut is covered by the factory original plastic cap.
