Future problems for 87 Carrera
Hi all,
I have an 87 carrera with 170k miles on the clock. What I was wondering is what possible future problems do I have in store? The engine seems strong so I am hoping that will last for a bit longer without a rebuild as long as I look after it. The bodywork apart from a bit of rust in the engine bay seems to be good. Any possible issues I should be aware of, or anything that is bound to break sooner or later? Thanks in advance John |
Czar of C.R.A.P.
Has anything been done. There are many, many items that will likely need to be taken care of on a car of that age (not esspecially due to mileage but age)
Rubber everything CV boots relube joints fuel lines Boots on front tie rods ends Shifter bushings Shifter coupling referrence sensors brake lines and fluid Check the throttle to be sure it is opening all the way Possible plugged CAT O2 sensor Cylinder head temp sensor Bushing in steering wheel column wheel bearings rear spring arm bushings for sure Probably front bushing Sway bar bushing front and rear for sure DME relay How are the brake pads Sorry about the list all the above can be done DYI........
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Hi there,
Sorry I should have provided more information, the fuel lines have definatly been replaced since it started spewing fuel everywhere ![]() I had a full service done with all the brakes etc done 2 years ago. Age is now taking its toll on the electricals. My car is UK so doesn't have an O2 sensor or cat, guess that is one advantage Should I be concerned about any rusting etc? There isnt too much at the moment. I was thinking of major problems that might cost huge money to fix, I am planning on slowly replacing the electrical and sensors during the year since it wont be driven much. Wondered if there were any massive things I should expect ![]() Thanks for the list, I will get them all checked when I get the car back. |
UFLYICU
I just rebuilt a 3.2 from an '87 for the track, and if I hadn't had to change the rod bolts, the motor wouldn't have needed a thing. I was absolutely amazed at how little wear there was inside. The crank only needed a little polishing, and I was back to std/std. If it isn't smoking at startup or under load, leave it alone. It'll keep on truckin'. My other one is an '88 which I commute with daily. 199k on the clock, no issues.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Have 164,000 miles on the clock. Top end rebuild 20K ago.
Pat
10 Ford Raptor 86 930 |
Non Compos Mentis
If you run into a tree, that would be a problem.
Other than that, enjoy the car. It will last a long time. |
