-   -   Do I have to replace my pressure plate during my clutch change? (http://forums.pelicanparts.com/porsche-911-technical-forum/337562-do-i-have-replace-my-pressure-plate-during-my-clutch-change.html)
Determined 03-24-2007 11:58 PM
Hi everyone,
I have an 84 3.2L Euro project coming to an end finally, I'm currently planning a transmission rebuild as well. I would like to know if I have to replace my Aluminum pressure plate as well or can I just do the clutch disc and release bearing?
Thanks,
Alex
Oh Haha 03-25-2007 04:51 AM
You could but why?
The money you save now will be spent later when you have to remove the engine to replace it. I thought about doing the same thing this year but my wife actually suggested getting the complete kit. I'm glad I did.
Rick V 03-25-2007 05:15 AM
JMO
When replacing any clutch pieces..............replace all of them, including all the bearings.
You might consider having the plate re-built if it;s cheeper.
Gunter 03-25-2007 06:49 AM
If there aren't too many miles on the plate, I'd re-use.
Some people are easy on the clutch and it shows when you look at the components.
Pilot bearing, release bearing and disc are relatively cheap.
Where to stop?
Have an experienced shop look at the plate and check the fork for cracks.
Determined 03-25-2007 07:49 AM
Thanks everyone, I hope I didn't blow it. I bought an aluminum pressure plate in good used shape and was going to go knew with the rest of the hardware. Are there any dimensions I should measure to confirm it's still good, other than a visual inspection of the forks?
Regards,
Alex
scottbooth 03-25-2007 07:50 AM
What about resurfacing the flywheel? That is another step that's included in most descriptions of the job, but it adds a lot of work.
I resurfaced the (presumably original) flywheel 8 years (and probably 40,000 miles) ago when I rebuilt the engine. Is there an easy way to tell if it is OK without removing it?
If I remove it I may well just replace it with a lightweight one while I am at it (this is a track car). Yet another slippery slope.
Scott
cashflyer 03-25-2007 08:00 AM
My 2 cents worth:
All those neat little fingers on the pressure plate, collectively, are a giant spring. They are what create the clamping pressure to hold the clutch disc.
Any spring, with age, will lose a portion of it's "springiness" and the result is loss of clamping force.
If your pressure plate is old, I would change it.
If your pressure plate shows signs of heat damage (from the clutch slipping) I would change it.
If you have any reason to doubt anything about the pressure plate, replace it.
That is, unless you really like removing the engine.
But if your pressure plate is relatively new with low miles, then I would probably reuse it. I have my engine and trans out right now, and will be going with a new clutch disc during the reinstall. However the pressure plate is less than 2 years old and has very low miles - and will be reused.
Scott R 03-25-2007 08:36 AM
In the midst of my complete engine and now transmission rebuild the part I kept was the pressure plate. Some yahoo had the clutch cable adjusted incorrectly when I purchased my SC and it was dragging. The disc was shallow, but the pressure plate was fine. My mechanic checked it out, and sent it out to be balanced with everything else on the motor.
Rodsrsr 03-25-2007 08:38 AM
The clutch disk and the pressure plate should always be replaced together, as well as resurfacing the flywheel. These parts need to wear uniformly. If you install a used pressure plate with a new clutch disk, their is a very good chance you will experience clutch jutter. Another item to change is the pilot bearing, and check the fork for excessive wear. Make sure you use new bolts when re-installing the flywheel as they can only be used once. It just doesn't make sense to go to the trouble of removing your engine/trans, than rebuild your trans, only to put in used parts. Just my .02
dean 03-25-2007 05:16 PM
IMO this is not true. If you are paying a mechanic to do the work then you replace everything cause you don't want to pay the labor again, if anything goes bad. But if you do the work yourself and understand the drawbacks of not replacing everything, then you can get away with not replacing everything. I have just done clutch disks many times and the clutch has lasted many miles and had no ill effects. The same is true with turning brake rotors.
Rodsrsr 03-25-2007 06:08 PM
Comparing a brake rotor to a clutch job may not be the best analogy, due to the level of difficulty in completing both jobs. I'm wondering if Dean is saying that using old parts CANNOT cause problems.HE may very well be able to identify acceptable wear on the pressure plate and flywheel. But based on determened"s initial question, I am assuming that he wants to do the job correctly the first time. It really comes down to cost vs benefit. The only benefit is that you will save a few bucks by using old parts. The flip side is; you will be using old parts, and you will probably be taking the motor out again soon to change the rear crank seal.
azasadny 03-25-2007 06:34 PM
Buy the Sachs kit from our host and replace all of the components in the kit and you'll be glad you did...
Grady Clay 03-25-2007 08:00 PM
I am a proponent of replacing even slightly suspicious parts. I’m
willing to spend a little more as opposed to risking an in-service
failure. A clutch is on the low end of this spectrum because it is
so easy to pull a 911 engine and replace a clutch.
That said, there is a serious issue with Porsche clutches (’70 and
later). The pressure plate is not designed to withstand use
decelerating the 911 with engine inertia. The tension springs in
the pressure plate are designed for only that use – tension. In
the reverse direction (when the engine slows the car) the
tension springs will buckle and ruin the pressure plate.
Here is an example:
http://forums.pelicanparts.com/uploa...1174877916.jpg
The tension spring should be straight. In this case it has buckled
and the guide pin is bent. The pressure plate is no longer
centered in the housing. The symptoms here are big vibration
and poor functioning of the clutch. Even subtle buckling renders
the pressure plate poor functioning.
Best,
Grady
EDIT for spelling
