fast idle
when I first start my sc the idle is low almost seems like its going to die, but it does not. I drive it and it eventually warms up.
then it stays at a high idle (2000-2500). If I shut it off for a few minutes than start it again, it idles normally. |
advance weights stuck in the dist. Usually happens when the ancillaries heat up and expand. Time to take apart and clean up... Use search.
Of course there are about A MILLION OTHER OPTIONS... usually the CIS gets misblamed. good luck Shawn |
Mixture incorrect/ improper timing/ fouled plug that clears after running/vacuum leaks/CIS malfunction/advance weights stuck in the dist
"advance weights stuck in the dist"
If that's the case, would you be able to "see" this problem with a timing light? I have the same problem, if less drastic. (idles great until HOT, then about 1500-1600 rpm.) |
Can you elaborate a little :) |
| All times are GMT -8. The time now is 10:05 AM. |
