"farking Porsche hero"
Trickle charger on an Optima?
Can I use a "Battery Tender" trickle charger on my Optima battery?
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
yup.
have had mine charging during this LONG WINTER!!!!!!!!!!! |
I sure hope so...I just bought $500 worth of Optimas (two) and Battery tenders for my boat. I got tired of replacing batteries every few years, and decided to try this route....suscribed.
THANKS!
I would say yes. I got me one also after I had the battery on the C4 die. It got sucked empty by the alarm would not take any charge. Now with the battery minder all seems to be good. Then for the Optima in the Targa I had the same issue. It was the Motronic and the clock that sucked the Optima empty. Well, another trickke charger and this should be a problem of the past.
If you go to the Optima website this is what is says in the FAQ about maintenance chargers: "Yes, you can use any charger on an OPTIMA as long as the voltage is regulated properly. If your charger will remain on indefinitely the voltage should be at 13.8 volts maximum with a one amp maximum current."
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Crusty Conservative
I have used a trickle charger on my WestCo gel-cels for about 5 years now. Everyone is still happy so I guess it's a good fit.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Senior Member
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Works great for me.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
I have a 800 ma Deltran battery tender, it takes about a day to charge up the battery after the car is put away but then it mostly idles after that. Works great with my red optima, and it was 25 bucks on ebay.
95' Mercedes E300 Diesel (Azure+Sodalith Blue) 88' Porsche 911 Targa (FOR SALE) (Guards Red) |
Slumlord
I think they are fine for maintaining a charge, but it will not recharge a dead battery.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
FWIW, Sherwood |
I also have uses a Battery Tender 1.5A and Optima Red for years without any problems. I also use the Battery Tender Jr. on my 998. I highly recommend.
================ Chris '87 Carrera Coupe '02 Ducati 998 |
I don't know if the trickle charger can maintain the battery. If you ever discharge the Optima...you have to jolt the Optima with a high amperage charge, prior to putting it back on the trickle charge or it won't charge at all.
Rick |
19 years and 17k posts...
I bought a C-Tech charger for my Optima and my Odyssey batteries and it works well..
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Thanks for the tip on the Jr...so far, the MTS 1000 hasn't sat still long enough for the battery to go dead.
yep ng on my car. Deep Cycle needs a marine style alternator regulator. My DC slowly lost max voltage over the course of 1yr. West Marine www.westmarine.com has a super sale on batteries 3/29-4/1. A good marine starter battery should have thicker plates than auto.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
