What is under the passenger seat?
In my 82 SC, (bought as roller), There is a large electrical connection there, but nothing to connect it to. What is supposed to go there?
i think the jetronic control unit goes there
82 SC , 72 914 |
If your looking to replace I have a tested good one $125
-Vinny 1983 911SC |
930 is correct. 82's did not have pwr seats.
On my '85, there was nothing under the passenger seat. My Rod Birch-installed amp is now there; the electrical connection you see could be left over from an old stereo installation.
Can't speak to the jetronic - I thought that and the DME were under the driver's seat.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
your 82 is Jetronic, no DME
like the pic
-Vinny 1983 911SC |
so, will i be needing that after a 3.6 install?
1982 SC.....currently undergoing the 3.6 conversion. 3.6 is sitting beside the car so far. |
no, you sure wont
-Vinny 1983 911SC |
Diss Member
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
okay cool, that comes with the engine, along with the harness, so that is taken care of.
It's a sickness really...
okay - now I'm confused. I have an '82 with the big connector under the pass seat as well. But this is no roller...it's my daily driver and other than poofing for a couple miles on startup it runs like a dream. How can that be without this "Jetronic" thing?
'88 Carrera Targa (Venetian Blue) '08 Mini Cooper (Blue w/ white top) '91 Honda CRX Si (white 100% stock) '65 Mustang (cream - dressed as a GT350) |
Wow, that is a Kinundrum!!! Good luck
Somatic Negative Optimist
There are 3 things under the pass. seat in your '82 SC: The OXS Control Unit (The brain for the Lambda), The Acceleration Enrichment Control Unit added in '81-'82, And the relay powered by the same fuse as the dome light to run the Lamda brain. If the car ever runs real crappy in idle, check the fuse for the dome light, the same fuse is necessary to run the Frequency Valve. The whole unit is often forgotten and neglected and gets rusty. Carefully remove the relay, clean the pins and use dielectric grease to put it back together. Carry a spare relay. in_style: You can remove the whole unit from the roller and sell it if it's good. Also, does your roller still have the Bosch CDI module on the left side of the engine compartment?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Thanks Gunter! - I have nothing but connectors under the pass seat. No box, no relays, nothing. Dome light works fine. Car runs fine at idle (great actually) once it's warmed up. I'm thinking (and this is on another thread called "Which CIS do I have") that the guy that put my motor together backdated my CIS to pre O2 sensor version, but I don't know how to tell.
Scott R - how do I tell if I have the Frequency valve? Pardon my newness to this CIS stuff...I'm reading posts as fast as I can without my boss or my wife getting annoyed...
I replied to your other thread.
Check the diameter (O.D.) of the intake runners. Those are the silver pipes coming from the airbox going to the top of the heads. If they are 47.5 mm, someone changed the CIS using an earlier '78-'79 system which doesn't have the Frequency Valve. That's o.k. except I don't know if Aircare is happy with that. Without the Lambda brain, the OX sensor or CAT isn't doing anything. Someone made some changes and a Porsche mechanic can tell right quick what was done.
yes i still have the cdi unit? why do you ask? do i need that?
Dick Cheney from what I understand under the Bush admin
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda |
in_style:
PM sent re CDI
anyone know where i can get a Acceleration Enrichment Control Unit im pretty sure mine has craped out. it doesnt appear as if pelican has them or any other place for that matter
82 SC , 72 914 |
