-   -   Headlight problem...dimmer switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/33809-headlight-problem-dimmer-switch.html)
Hatari 01-14-2001 07:12 AM
I have no driver’s side low beam, but brights on both sides. This is a restoration car and here’s what I’ve done so far relating to the lights:
-Got a replacement driver's side short harness for the lights/horns…plugs into the fender well. I thought the problem was with my old one as it had a sharp kink in it and the wires seemed damaged. The low beam problem was there before replacing the harness.
-Replaced the Hella bulb in the driver’s side with an exact duplicate as OEM.
-Checked all grounds, but the power is getting there.
My turn signal/dimmer switch on the yoke has no tactile click-stops anymore (planned to replace it anyway). Plus, my turn signals aren’t working although when you switch one on, the respective corner lights come on continuously. Could this switch be the root of all the lighting problems?
Thanks in advance…
Jack McAllister
Early_S_Man 01-14-2001 08:20 AM
Jack,
If there is power at the headlamp bulb connector that can be measured with a multimeter or test lamp, but the bulb filament doesn't light, try compressing the sides of that particular 1/4" quick disconnect connector with a pair of needle-nose pliers ... not enough to close the gap, just reduce it somewhat! Then slide it on a few times to make sure there is friction while applying. A bit of Dow Corning 111 Silicone Grease might help prevent corrosion.
Warren Hall
1973 911S Targa
Hatari 01-14-2001 10:28 AM
Thanks Warren,
I'll give that a whirl and let you know...
Jack
