-   -   Need a tolerance range (http://forums.pelicanparts.com/porsche-911-technical-forum/33812-need-tolerance-range.html)
blind dog 01-11-2001 11:37 AM
I'm intersted in knowing if a set of pistons which mic'd at 89.916mm and cylinders at 89.99 are acceptable for a stock 2.7. ANy info would be appreciated.
BD
Richard E. Boles
83930 01-14-2001 11:04 AM
standard piston size is 89.965-89.975 nikasil
89.952-89.967 alusil
piston cylinder clearance should be .0010-.0018 with wear limit of .0031
good luck hope this helps...
neil
