-   -   Torque Spec on SC Rotors (http://forums.pelicanparts.com/porsche-911-technical-forum/338168-torque-spec-sc-rotors.html)
Johnb911 03-27-2007 08:08 PM
Can someone tell me what the torque spec is on SC rotors to hubs.
Oh Haha 03-28-2007 03:59 AM
I believe it's 18 ft. lbs on the 13 mm bolts/nuts.
sjf911 03-28-2007 08:46 AM
17 ft-lbs
Gunter 03-28-2007 09:02 AM
What 13 mm??
They are 8mm nuts and bolts requiring 17 ft-lbs.
People confuse the wrench-size with the actual bolt-size. :)
Oh Haha 03-28-2007 03:43 PM
I know, I know, but if I had told him 8mm and he tried using a wrench on them he would have thought I gave him bad advice. :)
I always think of the wrench size when referring to fasteners. I thought everybody did this way.
Gunter 03-29-2007 10:01 AM
Bad habit, Wayne. :) We need to steer away from that.
Correct industrial application in SAE or DIN is to ALWAYS refer to the actual thead-size, NOT the wrench size, to avoid confusion.
Example: For the CV's, the correct torque for the 8mm Allen bolts would be for 8mm, NOT for the 6mm Allen key. ;)
Cheers
KTL 03-29-2007 03:58 PM
It's actually 18.44 ft-lbs since Germans use metric = 25Nm x 0.7375 ft-lb/Nm
:rolleyes:
