-   -   Unstable rev's when cold- 1 solution (http://forums.pelicanparts.com/porsche-911-technical-forum/33820-unstable-revs-when-cold-1-solution.html)
86ragtop 01-14-2001 04:30 PM
I was sufferring with a common problem it would seem for Carreras at least.
When cold the revs were all over the place.
I printed out all the helpfull threads suggested by Warren & Co. but descided to try the easiest first!.
How sensible! http://www.pelicanparts.com/ultimate/rolleyes.gif
I removed and sprayed with an aerosol (proper) 'electrical cleaner' all the plugs/sockets I could find incl. the Head temp sender.
As I cleaned all, I have no idea which was the culprit. But as she runs sweet, don't care!. http://www.pelicanparts.com/ultimate/biggrin.gif
Thanks Guys!
Ben
Nickshu 01-14-2001 05:11 PM
Ben,
Unstable rev's on DME engines is often caused by a bad air mass meter. This will cause the idle to "bounce" when cold. You can test yours with an ohm meter between 2 of the pins (you'll have to look up which pins and what ohms) However, if what you did worked, go with it!
Nick.
__________
Nick Shumaker
1982 911SC Coupe
[This message has been edited by Nickshu (edited 01-14-2001).]
