"farking Porsche hero"
Rich Lambert's Avatar
Trickle charger on an Optima?
Can I use a "Battery Tender" trickle charger on my Optima battery?
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 03-27-2007, 11:06 AM
aoua's Avatar
yup.
have had mine charging during this LONG WINTER!!!!!!!!!!!
1971 911T TARGA
http://www.pelicanparts.com/gallery/aoua/
Old 03-27-2007, 11:08 AM
I sure hope so...I just bought $500 worth of Optimas (two) and Battery tenders for my boat. I got tired of replacing batteries every few years, and decided to try this route....suscribed.
Old 03-27-2007, 11:09 AM
THANKS!
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 03-27-2007, 11:18 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I would say yes. I got me one also after I had the battery on the C4 die. It got sucked empty by the alarm would not take any charge. Now with the battery minder all seems to be good. Then for the Optima in the Targa I had the same issue. It was the Motronic and the clock that sucked the Optima empty. Well, another trickke charger and this should be a problem of the past.
If you go to the Optima website this is what is says in the FAQ about maintenance chargers: "Yes, you can use any charger on an OPTIMA as long as the voltage is regulated properly. If your charger will remain on indefinitely the voltage should be at 13.8 volts maximum with a one amp maximum current."
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-27-2007, 11:51 AM
Crusty Conservative
silverc4s's Avatar
I have used a trickle charger on my WestCo gel-cels for about 5 years now. Everyone is still happy so I guess it's a good fit.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 03-27-2007, 02:42 PM
Senior Member
Using one on my WestCo battery in the motorcycle right now.
Old 03-27-2007, 03:50 PM
Send a message via AIM to fintstone
Works great for me.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-27-2007, 10:04 PM
Originally posted by ischmitz
...If you go to the Optima website this is what is says in the FAQ about maintenance chargers: "Yes, you can use any charger on an OPTIMA as long as the voltage is regulated properly. If your charger will remain on indefinitely the voltage should be at 13.8 volts maximum with a one amp maximum current."
I've got a couple of "Battery Tenders" on the way that have a 1.5 amp current. I sure hope that's an insignificant difference but I seem to remember a caveat about following the specs. I've been using a different brand name tender (can't remember which) on my motorcycle for a couple of years and it works great. Has anyone had experience with the Optima Blue Tops (Marine/deep cycle)?
Old 03-28-2007, 04:01 AM
AvonGil's Avatar
I have a 800 ma Deltran battery tender, it takes about a day to charge up the battery after the car is put away but then it mostly idles after that. Works great with my red optima, and it was 25 bucks on ebay.
95' Mercedes E300 Diesel (Azure+Sodalith Blue)
88' Porsche 911 Targa (FOR SALE) (Guards Red)
Old 03-28-2007, 04:59 AM
Slumlord
Porsche_monkey's Avatar
I think they are fine for maintaining a charge, but it will not recharge a dead battery.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 03-28-2007, 06:47 AM
That was my assessment as well until my newish Optima (1/2005) died while sitting with a circuit discharge. I thought I'd have to awaken the battery by jolting it with a large charge like my previous Optima. Instead, I tried the trickle charger on it and next morning it was fine.
FWIW,
Sherwood
Old 03-28-2007, 03:56 PM
I also have uses a Battery Tender 1.5A and Optima Red for years without any problems. I also use the Battery Tender Jr. on my 998. I highly recommend.
Chris
'87 Carrera Coupe
'02 Ducati 998
Old 03-28-2007, 05:31 PM
rick conrath's Avatar
I don't know if the trickle charger can maintain the battery. If you ever discharge the Optima...you have to jolt the Optima with a high amperage charge, prior to putting it back on the trickle charge or it won't charge at all.
Rick
Old 03-28-2007, 05:41 PM
19 years and 17k posts...
azasadny's Avatar
I bought a C-Tech charger for my Optima and my Odyssey batteries and it works well..
Art Zasadny
Learning the bass guitar
www.ford.com
Old 03-28-2007, 06:33 PM
I feel better. I ordered a Battery Tender 1.5A yesterday.
Thanks for the tip on the Jr...so far, the MTS 1000 hasn't sat still long enough for the battery to go dead.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 03-28-2007, 07:44 PM
yep
ng on my car. Deep Cycle needs a marine style alternator regulator. My DC slowly lost max voltage over the course of 1yr.
West Marine www.westmarine.com has a super sale on batteries 3/29-4/1. A good marine starter battery should have thicker plates than auto.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-28-2007, 09:47 PM
