hank911
Guest
Posts: n/a
83SC UPGRADES
LOOKING FOR FEEDBACK FROM THOSE WHO HAVE BEEN THERE,DONE THAT.I'VE GOT THE 3.0 OUT TO DO THE TOP END AND A COUPLE HEAD STUDS,55K.I'M SWITCHING TO SSI'S & PRE 74 MUFFLER.ALSO LOOKING AT 964 OR G-60,OR "S"CAMS.ALSO LOOKING AT DOING SOME HEAD WORK W/THE VALVE JOB.EURO SPEC HEADS MUCH BETTER???FINALY I'VE SEEN A POSTING OR TWO ON CRANK FIRE IGNITIONS,THIS WOULD ELIMINATE RECURVING THE DISTRIBUTOR FOR THE CAMS BUT WHAT OTHER BENIFITS TO JUSTIFY THE COST???? OH,THE CARS A STREET DRIVER WITH A FEW AUTOCROSS & D.E.'S A YEAR.WHAT'S WORKED FOR YOU? UP'S AND DOWN'S AND RESULTS. THANKS IN ADVANCE AND I LOOK FORWARD TO POSTING THE RESULTS,,,,,MARCH????
Old 01-15-2001, 05:20 PM
mikez
Guest
Posts: n/a
The 964 cams are nice...did that, if you are into the bottom end...use the 3.2 crank, rods and pistons...consider carbs....
Old 01-15-2001, 06:03 PM
