-   -   Difference between H1 and H4 headlights? (http://forums.pelicanparts.com/porsche-911-technical-forum/338710-difference-between-h1-h4-headlights.html)
DougM 03-31-2007 05:21 AM
Any difference in the headlight or is it just the bulb? I can't seem to find anything in the search?
david914 03-31-2007 06:03 AM
Re: Difference between H1 and H4 headlights?
Difference? About $700. :D
Other than that, they're very different. H4's use one H4 lamp and a single reflector. The H1's use two H1 lamps, each with their own reflector. The lenses are different as well to accommodate the different reflector configuration.
eki912 03-31-2007 06:38 AM
Precisely ! H4 is really good , and cheap , both filaments in one bulb.
H1 is more expensive , one bulb serves one purpose only.
MattAlpha 03-31-2007 07:05 AM
Mainly since H1's have two reflectors and two bulbs, you can point each reflector to shine the high and low beams in different directions if that is what you prefer. H4's have both filaments in the same bulb, hence the need for a single reflector.
-Matt
DougM 03-31-2007 07:06 AM
PAUL RODELO 03-31-2007 07:20 AM
Doug,
If you are working on an early 911...73 and previous, I recommend the use of H1's. They are period correct and have a unique look when driving with low beams....cat-like. Since they are rare....they are pricey. See pic of my 70 911.
http://forums.pelicanparts.com/uploa...1175350705.jpg
I remember a guy selling a NOS set 2 years ago for $1500. At the time that was a lot of money. That is nolonger the case. H4's are great....I use them on my 930
http://forums.pelicanparts.com/uploa...1175350786.jpg
Best of luck in your search/purchase.
Paul
Goth 03-31-2007 09:05 AM
Anyone know if the headlight rims are interchangeable?
Thanks!
Zeke 03-31-2007 11:46 AM
Not the base rings. H1's have four adjuster screws, H4 have 2.
pwd72s 03-31-2007 11:58 AM
Perhaps this is a better pic of H-1's...showing the adjusting screws...the fog light is factory original
http://forums.pelicanparts.com/uploa...1175367523.jpg
frankc 03-31-2007 03:27 PM
Here's a closer picture of an H1 on my 77 with the trim ring installed.
http://forums.pelicanparts.com/uploa...1175380040.jpg
Goth 03-31-2007 04:20 PM
I got it now... Thanks for the info/pics :)
DougM 03-31-2007 07:33 PM
Thanks everyone.
The reason I asked was that these were at $330 with 30 minutes to go this morning.
http://cgi.ebay.com/ebaymotors/Porsche-911-912-930-H1-Headlights-BOSCH-H1_W0QQcmdZViewItemQQcategoryZ33710QQitemZ26010063 8895QQrdZ1QQsspagenameZWDVW
I have H4's already, but never knew the difference. I didn't know if it would be a upgrade or not.
Sorry, link does not work but they ended up at $540.
