-   -   DME Chip Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/338800-dme-chip-problem.html)
Por_sha911 03-31-2007 03:17 PM
DME Chip Problem
A friend of mine has an `85 Euro 3.2 The car ran very strong up to 5600 rpm and then interrupted like a rev limiter was kicking in. He changed the cap, rotor.... and it still ran only up to 5600.
He pulled the DME and tried to check to see if had an aftermarket chip and found a chip that had a small glass window in the center of it with what looked like a tiny silicon circuit chip under the glass (marked NEC and Japan). To make matters more uncertain, the DME had some marker pen writing on the outer case which makes him wonder if it has be swapped out.
When he tried to pry the chip out it busted!:eek: Most of the prongs broke off the chip when it broke and he had to pull the prongs out of the board with a needle nose plier. It appears that he had a chip that was soldered in. He has another stock Motronic chip but it is for a US car. He tried putting it in the board but the prongs of the chip don't go down into the board (more evidence that the old chip was soldered in although we thought they were only soldered up to `84). He tried to put the US chip in to see if it would work but it turns over but doesn't fire and the chip won't stay in place very well. When you hold the board up to the light, some of the holes have light coming through from the solder side and others don't.
His questions: Can he just carefully drill out the holes or solder points on the flip side of the board with a tiny drill bit or does the new chip have to be soldered in as well? Can he use a US chip with a Euro motor? How can he tell what is currently in the car (at least what's left of it)?
Any and all help greatly appreciated but please answer from expertise or experience versus "I think" or "it should"
88-diamondblue 03-31-2007 03:30 PM
You need to wick the solder out with an soldering iron and solder wick. If you drill you run the risk of damaging the pc board of the Motronic unit. He must have really pried hard to get the chip to break. The chips are hard to break. Yes it would need to be soldered or a socket soldered in place to put the chip in.
I would contact SteveW at www.911chips.com and have him put in a chip socket and get a performance boost while you are at it. If he damages it any more it will cost way more than sending it in to Steve and getting it done right.:D
PSJoyce 03-31-2007 03:35 PM
I just took the stock chip out of my 1985 today. Under the label, the stock chip (labeled 1267355102) did have the small round window, with the tiny chip under it, just as you describe. It was also labeled NEC Japan, but had no marker pen writing.
I can shoot a photo later if it helps.
And, Steve at 911Chips is a great resorce.
Paul
jmgin2 03-31-2007 05:22 PM
Those chips aren't supposed to be soldered in except in some 1984s when the factory did that. don't solder the new chip in it should just gently snap into place. A US chip will probably run the car but won't be able to support the freed up exhaust and the higher compression engine and will lose power. Other words, its a waste of time to try it.
I am looking at the stock chip from my 85 carrera and there is no glass window like you guys say. anyway, I afraid he might need a new ecu, again steve at 911chips.com is always a good resource
Jim
ischmitz 03-31-2007 06:37 PM
The fact that the chip has a window tells you you are dealing with a UV-erasable EPROM. The marking is the manufacturer. It doesn't tell you what was on the chip. Some later pin-compatible PROM's do not have the window and you can not erase them.
It sound like your buddy ripped the chip out of the PCB board rather than out of a socket. This is bad. He most likely did pull some of the through-contacts (for lack of a better word) out as well. These through-contacts connect the coper traces on the top to the ones on the bottom. To fix this properly you need an antistatic de-soldering pump and good soldering skills to remove the remaining solder from the filled holes. I would NOT use solder wick. Next you want to inspect which coper traces and patches have been damaged and repair them. Then solder in a DIP-24 or DIP-28 socket. I would leave this to a professional. Otherwise chances are the DME becomes a paperweight.
Good luck,
Ingo
Nine9six 03-31-2007 07:14 PM
Why not try to replace it with a used euro DME?
ischmitz is absolutely correct regarding the soldering and traces.
If there are any ESD sensitive components on that board and you go at it with an incorrect type soldering iron, might as well slap some butter on it, cause it'll be toast.
stlrj 04-01-2007 06:59 AM
But he didn't replace the ignition cables???
Joe
Nine9six 04-01-2007 07:19 AM
Joe
Some, after reading the posts, would agree that the issue is chip related and not plugs, rotor, cap...Beru or Magnecore wire sets are NOT $20 items.:eek:
I wouldn't have changed them either, based upon what the guy was trying to achieve.
PSJoyce 04-01-2007 07:29 AM
For reference, the following photos are of the stock chip from my 1985, with the label peeled back. The chip number is a stock number, and the DME showed no evidence of being opened before I opened it yesterday.
Paul
http://forums.pelicanparts.com/uploa...1175437627.jpg http://forums.pelicanparts.com/uploa...1175437640.jpg
ischmitz 04-01-2007 08:06 AM
Paul,
according to the laser marking this is a 2kx8bit EPROM made my NEC in Japan in the 12th week of 1984. This is all you can see. There is no way of telling what is actually written to the chip. You have to read it in an EPROM programmer and look at the code.
BTW, be careful and do not expose the chip to direct sunlight for too long. The quartz window needs to be covered to not erase the chips memory content. Especially as these chips come of age chances are that bits start to "tumble" and exposing the window to sunlight or other UV sources will accelerate this process.
Cheers,
Ingo
PSJoyce 04-01-2007 08:10 AM
Thanks Ingo -- I should have thought of that. The label is back in place, and the chip itself is safely in the nice little plastic case that Steve Wong ships his chip in.
Paul
Wavey 04-01-2007 08:15 AM
100% agreed. Send it to Steve Wong.
I'd be doin' plug wires too, BTW.
Lorenfb 04-01-2007 08:42 AM
At this point it's best to convert it to a 28 pin DME ECM which is basically
what a performance chip attempts to do. This also results in an overall better
running engine without the potential problems of a 24 pin performance chip.
Besides major fuel & ignition map changes, the 28 pin DME ECM has changes
to the overall Motronic engine management algorithms. As an example, the
idle system has less of an undershoot on decel and the engine starts better.
These Porsche/Bosch upgrades resulted in the best overall running 3.2 911,
i.e. '88/'89, of all the '84-'89 911 3.2s.
Bottom line: All 3.2 DME ECMs should be converted to a late 28 pin DME ECM
and not waste money with 24 pin performance chips. This is a VERY significant
improvement noticeable from the moment the engine is first started after
the conversion, i.e. the engine will idle smoother and be more responsive
especially when cold.
Also, send the DME ECM to Pelican Parts as they have many suppliers capable of
reliable & quality repairing and/or upgrading the DME ECM.
ToddM 04-01-2007 08:42 AM
If he yanked on this board that hard to pry a soldered in DIP IC out, I would suspect now that board may be permanently damaged.
First, are all the board contacts even still present? If so, I would solder in a DIP socket. You can find these off digi-key or mouser or whatever.
The chip is definitely a goner and you will need a new IC.
Even if you replace the IC, there could now be a broken trace or open via somewhere else on the board.
I don't see anything out of the norm with the original chip, it's manufacturer, the fact that it was an UV PROM, or that it was soldered in as the factory sometimes did.
I think you friend may have damaged something that never had anything wrong with it to begin with.
Por_sha911 04-01-2007 08:19 PM
Thanks for all the info.
PSJoyce: Yup, that was the chip before he broke it (but it had a round sticker over the window).
Loren: I see what you are saying about the 24 vs 28 pin chip.
The first thing he'll have to do is see if the board is toast from ripping the old chip out. Can anyone tell me if its possible that he had the factory DME with a soldered chip in an `85 Euro or is that an indication that the unit has been replaced?
Nashville84Cab 04-01-2007 09:20 PM
Hey Joe,
Besides the incurred chip problem, sounds like your friend is experiencing issues with the speed sensor. After getting the chip/DME problem fixed, I would suggest him to take a look at the gapping between the speed sensor and the fly wheel.
I spent alot of money, headaches, and time chasing the exact problem (replaced DME chip, DME itself, plugs, wires, cht, AFM, most ignition related parts, and even new Speed and Ref sensors). It turned out that my speed sensor was gapped to close to the fly wheel and causing a misfire that acted like a rev limiter at the exact RPM every time (~4800).
If he has no luck finding ROW DME or repairing his, I do have my extra DME if he wants it. I was planning on keeping it, but I guess there really is no need for it anymore as my Rev Limiter problem was the speed sensor gap.
BTW, your friend will be amazed at the difference in HP between RPM's at 5600 vs redline (near).
I bet Steve Wong could repair and make a chip for the Euro 3.2. I just reinstalled my Autothority MAS with Steve's chip for it and it runs very strong!
Good luck,
Darrell
ToddM 04-01-2007 10:08 PM
You would have had to read the contents of the IC, but now that the IC is permanently damaged, that is not feasible.
It seems more than possible to me that the factory could have soldered in the original DME in 85.
Wayne 962 04-02-2007 02:26 AM
I would have someone else put a new chip socket in - it sounds like he's not too much of a master with the soldering iron...
-Wayne
MotoSook 04-02-2007 04:34 AM
Are you sure he was prying on the chip and not the socket that the chip is installed in? Can you post a picture?
Regardless, it sounds like you need a new socket. Send it off to a professional and get it upgraded.
Lorenfb 04-02-2007 07:19 AM
Key EPROM differences of Euro (24) vs USA (24) vs USA (28):
Timing Maps
Idle - Euro(24) & USA(24) are the same, USA(28) a few degrees more advanced
Part Throttle - Euro(24) is a few degrees more advanced than USA(24) with
slight differences with the USA(28)
Full Throttle - USA(28) is a few degrees more advanced than both 24 pins
Fuel Maps
Idle - Euro(24) is slightly more rich than both USA chips
Part Throttle - Both USA chips are slightly richer than the Euro
Full Throttle - Slight differences between all three
There's very little difference between the Euro and USA chips as can
be explained by the higher CR of the Euro engine but then offset by
the higher octane availability, i.e. the ignition timing is basically the
same.
"Can anyone tell me if its possible that he had the factory DME with a soldered chip in an `85 Euro or is that an indication that the unit has been replaced?"
Basically all the early 3.2 DME ECMs had soldered in EPROMs.
"Yup, that was the chip before he broke it (but it had a round sticker over the window)."
Bosch always used a rectangular sticker as posted earlier which indicates
that the EPROM might have been replaced or the sticker was.
Lorenfb 04-02-2007 07:29 AM
http://forums.pelicanparts.com/uploa...1175524108.jpg
The circled area indicates the component difference between the USA and the
EURO DME ECM, i.e. the O2 system. The EURO DME is the upper image without
the components.
Hendog 04-02-2007 08:22 AM
and not waste money with 24 pin performance chips. .
It's been a while since I looked inside the box, but I know I have a 24 pin. Was the board manufactured with the extra 4 holes to accomodate a 28 pin chip in 1987? Were they moving in that direction at that time?
Lorenfb 04-02-2007 08:25 AM
"Was the board manufactured with the extra 4 holes to accomodate a 28 pin chip in 1987? Were they moving in that direction at that time?"
Yes to both.
Hendog 04-02-2007 08:30 AM
Yes to both.
How much work is involved in updating the board to accomodate a 28 pin chip? I make my living with a soldering iron:) .
ToddM 04-02-2007 09:07 AM
get a 28 pin DIP socket, remove the old 24 pin DIP socket, and install the pin DIP socket. The PCB is the same for both versions so the extra holes are there to accomodat eit already.
Por_sha911 04-02-2007 04:18 PM
The circled area indicated the component difference between the USA and the
Which is the Euro?
Lorenfb 04-02-2007 05:41 PM
"Which is the Euro?"
The upper image is the Euro.
jbrinkley 04-02-2007 05:54 PM
gosh.......... I feel bad, I have three 24pin chips
Steve W 04-02-2007 10:12 PM
Before anyone feels bad, some of the information presented here is seriously erroneous and needs correction.
a) there is no advantage going from 24 to 28 pin. The coding is identical. In the 24 pin setup, On the U.S cars, once you convert from 2k to 4k, and use the appropriate chip, there is absolutely no difference between that and a 28 pin chip - the programs are identical. On the European cars, it is a waste of time and makes absolutely no difference going from 2k to 4k, or converting to 28 pin.
b) you do not want to convert a 24 pin Euro box to 28 pin. Not only is there no advantage, but you start causing more confusion, as you will need to configure additional wiring and need a Porsche part adapter to select the correct Euro spec map in the 28 pin program, which again is idential to the original Euro spec 2k program. Without proper configuration and the necessary adapter, it will be running the default U.S. maps.
c) There are some major difference between a Euro and US chip. A Euro chip will not recognize the O2 sensor, and without going into excess detail, because of the differences in the fuel and ignition maps, it responds and performs differently.
Joe, I take you got my reply to your email, but if not, basically it does not sound like a big deal what your friend did and should be salvagable, but for now, he should not be within 50 feet of that DME with a soldering iron(or any power tools for that matter). He ripped the original soldered in chip out of the board. I would have a 24 pin socket put in and another copy of the proper Euro chip installed. The rpm limit sounds like a rpm sensor issue.
Lorenfb 04-02-2007 11:00 PM
"there is no advantage going from 24 to 28 pin. The coding is identical"
Please! Porsche/Bosch just doubled the EPROM memory (4K>8K-28pin)
because they just wanted to make manufacturing production
changes without any benefit. RIGHT! It has been posted on Pelican
Parts by others about the switch to the 28 pin EPROM and its benefit
early on when Pelican first started the web site. These benefits have
been posted before on this thread. It's very obvious that the above
statement is indicative of a lack of understanding of the 8051up and
its memory addressing modes and how the 3.2 DME ECM really operates.
"you do not want to convert a 24 pin Euro box to 28 pin. Not only is there no advantage, but you start causing more confusion, as you will need to configure additional wiring"
Totally incorrect as those who have exchanged late DMEs with
early DMEs in an early car did it WITHOUT wiring changes.
That's the purpose of having a socketed EPROM, i.e. to make production
upgrades without making major production changes (wiring).
"need a Porsche part adapter to select the correct Euro spec map in the 28 pin program"
More misinformation! Porsche shops have been exchanging Euro & USA chips
wihout any "part adapter" (Do what??????) for over 20 years in both DMEs.
THAT'S THE PURPOSE OF USING AN EPROM!!!!!!!!!!!!!!!!!! Versus using a
fixed coded (no changeable firmware) microcontroller (ECM). Bosch just
changed the EPROM for various markets, e.g. ROW or USA/Japan, which
was also the case for basically all the 964 DMEs. There's NO such thing as
a "part adapter", i.e. more hyperbole.
"Euro chip will not recognize the O2 sensor, and without going into excess detail"
So!!! All who really understand the 3.2 911 are quite aware of this.
Guys running a Euro DME couldn't care less about the O2 sensor anyway.
As was posted before, the Euro & USA maps are basically the same.
And, "excess detail", like what??? More hyperbole maybe? Please!
Bottom line: The upgrade to a late 28 pin DME ECM is significant
as has been verified by all Porsche shops that have used a late
DME in an early car. This has been known for over 15 years now,
but for some may be not. Many knowledgeable Pelican guys
who have been involved with 911s over the years are aware
of this too. Many Porsche shops request this upgrade when
their customers' DMEs require rebuliding, as a value-added benefit
without the problematic issues of a performance chip.
Actually, the 28 pin EPROM setup allows the 3.2 DME ECM with
the proper EPROM to have diagnostics and a CEL (check engine
light). Just take a look at the DME schematic. It's all there!
As mentioned by another poster, Porsche/Bosch was thinking ahead
when the 3.2 DME ECM was initially developed.
Steve W 04-02-2007 11:23 PM
Well, since you seem come off as such a expert, why don't you tell us all specifically what is the advantage of going from 24 to 28 pin - and no technobabble jibberish assumptions. List exactly what are the performance differences and why. Without real facts, your statements have no merit. I heard it so because someone told me so doesn't count.
And of course there is a difference between a U.S. and Euro chip, or I would not state so. I am not here to teach a chip programming class, so if you don't know the differences, and don't like my clarifications, too bad.
Over the years, many of your past posts are so full of errors and misleading information, you should be prohibited as making erroneous statements as a self proclaimed expert is the most dangerous of all. I could post links to many of them, but I don't have that kind of time. If you only heard all laughs and jokes from shop, tuners, and manufacturers regarding the errors of your posts.
Nine9six 04-03-2007 12:32 AM
Ahh, forget about all this and just change the plug wires. That oughta git er done.
Sorry fellas, I couldnt resist.
MattAlpha 04-03-2007 08:19 AM
On a side note, once I get my suspension fixed up, I'll be purchasing one of Steve's chips. Just thought I'd mention that.
-Matt
The Chef 04-03-2007 09:35 AM
BUY STEVE W CHIPS! BUY STEVE W CHIPS. ISNT THAT EASY TO SAY! HAVE A NICE DAY!
ToddM 04-03-2007 09:38 AM
I think the real laughable thing about all of this is that somebody looked at something, thought it looked weird, and completely pried it out of it's PCB when it had zero issue and was probably stock from the factory.
Makes you really think before buy ANY used car.. just what dolt(s) owned it previously
theiceman 04-03-2007 03:38 PM
Do Steve and Loren agree on anything ? seams like two very knowlegeable guys with differing opinions, if they were to work together in the analysis we would all be better off.
scottb 04-03-2007 04:28 PM
Originally posted by theiceman
.... if they were to work together in the analysis ...
That's about as likely as the Israelis and Iranians working together to achieve Mid-East peace! :eek:
88-diamondblue 04-03-2007 04:52 PM
Iceman,
Getting helpful information from Loren is a feat all in it's own. There are the derogatory comments and the rhetoric that goes with it. The discussion has been had about "if you have the information" why not share that info. Steve W has done that clearly and concisely when ever help was asked of him. His technical support is awesome as well. I know where my trust is and many others are on this issue.
Do a search on "chips" and read a few of them since there will be many. Loren has attacked Steve so many times that it has has just become ridiculous. He also has been temporarily banned here and at Rennlist for his bad behavior. Other posts at Rennlist were sent to the abyss by the mods because of nasty posts. Grab a brew or two and start reading, you will understand more about it.http://www.pelicanparts.com/support/smileys/wat6.gif
Flyer88 04-03-2007 05:20 PM
Originally posted by Nashville84Cab
Hey Joe,
If he has no luck finding ROW DME or repairing his, I do have my extra DME if he wants it. I was planning on keeping it, but I guess there really is no need for it anymore as my Rev Limiter problem was the speed sensor gap. And Steve, the chip is awesome - going to Mid-Ohio in 10 days and can't wait to give it a workout with all systems performing correctly!
Good luck,
Darrell
I agree with Darrel on the crank sensors. I was having a "jumping" issue under hard acceleration and had replaced the cap, rotor, wires, plugs, O2 sensor, and WOT sensor (all after having replaced the clutch and installing a Steve Wong chip in a 24 pin DME). Turns out one of the crank sensors was bad - replaced it with a used part (for now) and it runs stronger than ever. BTW my wrench informed me that BMWs use the same sensors (with a 3" longer wire) and they sell for 1/2 the price.
Nashville84Cab 04-03-2007 09:52 PM
Originally posted by Flyer88
I agree with Darrel on the crank sensors. Turns out one of the crank sensors was bad - replaced it with a used part (for now) and it runs stronger than ever. BTW my wrench informed me that BMWs use the same sensors (with a 3" longer wire) and they sell for 1/2 the price.
Yup I think someone else here purchased the BMW sensor, but never really confirmed if it worked the same... but my guess is that it will work (looks like an identical Bosch part).
But before your friend goes purchasing and replacing parts, I would recommend he first swap the speed sensor (aka rpm sensor) and the reference sensor (same part) to see if the speed sensor is actually working. If you get a no start, then the possible problem is that the swapped sensor is bad. If you still get the "rev limiter" then from my experience, the gapping on the speed sensor is slightly off and not magnetically picking up the flywheel teeth at the higher rpm... hence the rev limiter. In my situation, my speed sensor was too close to the flywheel. Did he have a recent work on flywheel or tranny?
BTW, I should give credit where credit is due: I had called Steve Wong about getting one of his chips to solve my rev limit problem (perhaps thinking the same as your friend in that the DME or chip is the problem as a last resort) and Steve told me that the problem is not with my current chip nor DME, but with the speed sensor... he was right (as he and Flyer88 mentioned in this post)!
After replacing many parts, I now have extra speed and ref sensors if your friend needs them.
Best regards,
Darrell
