Richard Burns's Avatar
Front Vent Water Leaks
After a day at the track in pi**ing down rain I arrived home to find that I have a water leak from the plenum chamber at the front of the car. Has anybody had this experience and where do I start to fix it?
This is on a R O W Carrera 3. Any help would be appreciated.
Thanks in advance.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 03-28-2007, 11:31 PM
Make sure the drain hose is properly connected and replace the seal that fits between the blower housing and the opening in the car's sheet metal. It's pretty easy.
JR
Old 03-29-2007, 02:17 AM
like javadog said..also I would guess that bad trunk lid seals would be messy in a heavy rain.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 03-29-2007, 01:06 PM
Thanks for the help guys. It turned out that a previous owner had cut off the drain tube. As it hasn't rained here for 5 years I wasn't aware of the problem 'till the wet track day.
Thanks again.
Old 03-31-2007, 08:36 PM
