Repainting Fuchs Question--Orange Peel
Getting some orange peel on the finish with the Rustoleum spray. What am I doing wrong? Thx
1980 911SC Targa 3.6L
Old 04-02-2007, 06:31 AM
Super_Dave_D's Avatar
I think its too much and too close
Hold the can 10 - 12 inches from the surface and spray in a smooth motion, applying several light coats. Several coats is the key. Sand down the orange peel and re-spray.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 04-02-2007, 06:39 AM
dlagerstrom's Avatar
What did you use for a primer?
Orange-peel is usually caused by something on the surface that is keeping the paing form adhering properly.
I used a self-etching primer as it is the best bet when trying to paint aluminum.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 04-02-2007, 07:03 AM
Thanks--I scuffed the already painted surface with 180 grit then painted. I am not painting directly on aluminum. Do I still need a primer over the scuffed paint surface?
Old 04-02-2007, 10:20 AM
Slumlord
Porsche_monkey's Avatar
Clean it with laquer thinner, then spay the scuffed surface.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-02-2007, 10:23 AM
Harlan Chinn's Avatar
Try this: Assuming that the surface is prepared and primed.
Decant your rat can of paint in a bucket of hot water;Make sure the nozzle is clean and clear of old paint; shake well and wipe off excess water; wipe clean the surface to be painted with lacquer thinner; be sure to paint in a location that is within the temperature range on the can's instructions; warm the surface (wheel) to something near the temperature of the room or warmer; spray the paint close enough that the paint lands on the surface "wet" and watch for the paint to "level" or flatten out but not so close that it begins to build-up and run; Keep the can moving from the center outward; lightly sand between coats with 1500 grit paper to remove any dust and complete the painting in a single session. That means don't wait a couple of days to apply subsequent coats of paint.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 04-02-2007, 11:14 AM
fastfredracing's Avatar
Hey, that is a great idea of dropping the paint can in hot water, I usually do a lot of my engine work in the winter, and the my shop is not the warmest place. I will give it a try, I usually put the paint can and parts in front of the heater prior to painting, never though of hot water
thanks
No left turn un stoned
Old 04-02-2007, 02:18 PM
