-   -   Newbie antiseize question. (http://forums.pelicanparts.com/porsche-911-technical-forum/338978-newbie-antiseize-question.html)
billroth 04-01-2007 07:53 PM
After browsing tons of threads on removing siezed fasteners of one sort or another, I wonder if you should put antiseize on everything.
Is there any place you shouldn't?
Lawrence
speedracer 04-01-2007 08:53 PM
Spark plugs for one...
Danny_Ocean 04-01-2007 09:02 PM
I would only use anti-seize on stuff you have to remove regularly for maintenance (drain plugs, wheel lugs, etc.). Above poster says not to use it on spark plugs, but I have in the past (on American V8's) without incident.
911pcars 04-02-2007 02:11 PM
"I would only use anti-seize on stuff you have to remove regularly for maintenance (drain plugs, wheel lugs, etc.). "
And for fasteners that aren't regularly removed, use nothing? That sounds like a short-sighted solution. Here's one reason to not use; don't use anti-seize if you never plan to disassemble a threaded component (for eternal optimists).
Any time dissimiliar metals are in contact there's a galvanic reaction that results in molecules co-mingling. This results in separate parts becoming one with the earth. More so with threaded fasteners. Even similar metals do this (repeat this 12 times; "Heat exchanger nuts").
To ensure parts can be separated at a later date, or earlier than you anticipate, use antiseize, but sparingly. Wikipedia should insert a large description under the term "sparingly". Although some would differ, I put a small dab onto spark plug threads. On a 911, spark plugs (steel) thread into cylinder heads (aluminum).
Sherwood
Danny_Ocean 04-02-2007 02:22 PM
On "permanent" or "semi-permanent" parts, I use Loc-Tite red or blue.
rfuerst911sc 04-02-2007 02:45 PM
I have been back yard wrenching for about 35 years and I put anti-seize on everything I take apart or replace including spark plugs. I check some items regularly ( plugs,wheel lugs,suspension parts ) for torque and have never had an issue. I use the standard silver goop you buy over the counter. Like anything else "moderation" is the key, just a thin coat is needed. Just my amateur 2 cents.
sig_a 04-02-2007 03:25 PM
I just finished reinstalling my entire stock exhaust system including the heat exchangers and used copper paste type Lubro Moly Anti-Seize Compound liberally. Why the recommendation to use "sparingly"? The nuts are mostly "prevailing yield lock" type.
