-   -   Need Multimeter Recommendation (http://forums.pelicanparts.com/porsche-911-technical-forum/33915-need-multimeter-recommendation.html)
JJ 911SC 10-27-2017 03:29 PM
Almost 17 years, could be a record.
Originally Posted by ian c2 (Post 9793027)
911pcars 10-27-2017 03:34 PM
A precaution using a 12V test lamp:
Modern ECU circuit sensors operate at/or about 5v and low current. If a 12V test lamp is connected to test for available/source voltage, the system will attempt to supply12V. The resulttant excess current draw could damage the ECU.
Sherwood
Antonov 10-27-2017 05:45 PM
Fluke 87, I have a 787 sourcing fluke, but really an 87, shouldn't have any problems finding one for a good price
ian c2 10-27-2017 07:23 PM
I’ve shot millions of loops at work , not one on a 911 ....
:D
My home fluke is a 787 too though , (As well as an Emerson 475 ;) ) and perhaps the easiest and best of all is a little t6-1k that fits in your back pocket ..
mainly 789 And 754 for work though , and the 773 is pretty good for clamp-on 4-20mA ..
ceptanko 11-18-2017 08:54 PM
What do you think about fluke 117 multimeter? I am thinking to buy this multimeter. I have no idea about the best multimeter. Just read about the best multimeter and find there a list. Among that list, I think 117 could a good choice. Please share your personal experience about this multimeter.
rwest 11-19-2017 02:12 AM
That's a good one and should do fine for working on your car and around the house.
billybek 11-19-2017 05:56 AM
That is a very nice meter and more than most will need.
Fluke meters have very good fusing that protect the meter and the operator from being damaged.
This is what makes them a good investment. My at home meter is an old Fluke 23 that I have owned since about 1994.
Some of these older Flukes are available at very reasonable prices and still serviceable by the manufacturer for repairs and calibration.
T77911S 11-20-2017 04:04 AM
you don't need an expensive MM.
I have expensive 87's and a cheap craftsman. the craftsman works fine.
test light works great too.
just used the TL on my BMW starter the other day,
by myself so I propped the TL on the start wire, put my phone on video and hit the ignition sw. I could see the light light just fine on the video.
Sindhu002 01-31-2019 10:22 PM
I use Extech MN35 multimeter. I dont have any knowledge about best multimeter. Just read the Best multimeters in the site and find the best one.
Sindhu002 01-31-2019 10:25 PM
I use Extech MN35 multimeter. I dont have any knowledge about best multimeters. Just gone through the Multimeter siter and understood some lists.
Sindhu002 01-31-2019 10:27 PM
I use Extech MN35 multimeter. I dont have any knowledge about best multimeters. Just gone through the Multimeter site and understood some lists.
nhantruong6989 02-26-2019 06:54 PM
I have chosen Hioki products from Japan for a long time. Because of the quality and efficiency it gives me. When using the multimeter Hioki DT 4256 I am really impressed with its measurement capabilities. It can perform 11 different parameter measurements for comprehensive power testing. AC / DC voltage measurement: 600.0 mV to 1000V; Hi scale measurement: 40V- 600V & ladder Lo: 80 -60V; measure resistance, measure frequency ... with high accuracy. The ability to measure True-Rms of power parameters with real effective values ​​increases reliability and minimizes errors. The device also features a 100 Hz low-pass filter that helps users accurately measure even harmonic harmonic components. The device supports extremely convenient data access via USB connection port. Especially I own it at a very attractive price, when ordering at Techmaster Electronics J.S.C.
