Meka's Avatar
Sunroof question
The front driver side of my sunroof is a bit higher than the passenger side. Looking up at it from the seat I see a small gap. It looks like it needs to come down about 1/16. Would I adjust this with the nuts that are under the channel guides? If so, where is the channel guide? Is it on the part of the sunroof that retracts? Do I need to pull the sunroof to get to this adjustment? Thanks
1984 Carrera
Old 04-22-2007, 10:10 PM
Kantry Member
oldE's Avatar
Meka
You should be able to get a good idea of what you need to do here:
http://www.pelicanparts.com/techarticles/911_sunroof_repair/911_sunroof_repair.htm
Lots of good stuff in the Tech Info Center
Have fun
Les
Best
Les
Old 04-23-2007, 05:52 AM
Meka's Avatar
Originally posted by oldE
Meka
Have fun
Les
Thanks Les,
I have the 101 Projects book and read the sunroof section throughly but it does not say exactly where this adjustment is. I don't want to pull it unless I have to.
1984 Carrera
Old 04-23-2007, 07:23 AM
Registered Cruiser
jorian's Avatar
Meka,
You have to pull down the inside panel on the sunroof itself. Open the roof about 4" and firmly pull down on the front edges and work your way to the back. With this removed it will be apparent to you which screws do what. Getting the right height is trial and error but it shouldn't take more than an hour.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 04-23-2007, 08:58 AM
Meka's Avatar
Originally posted by jorian
Meka,
Thanks Jorian. That was the info I needed. Also the last place I would look.
1984 Carrera
Old 04-27-2007, 07:30 AM
Registered Cruiser
jorian's Avatar
Good to hear it worked out for you.
Old 04-27-2007, 08:18 AM
