Oil Temp Gauge
If I add an aftermarket VDO oil temperature gauge will it work with the OEM VDO oil temp sender, part# 91160611200?
1985.5 944 GTS |
No idea.
If you look at the sending unit, it should have a temperature number stamped on it. If this is the same as the maximum number on the gauge, then MAYBE it will work. I'd suggest checking the gauge and sender off of the car, with a thermometer and a pan of oil on the stove. JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
MBruns for President
Pretty sure you have to change -
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
