Typical Salesman
jeffrey2's Avatar
Dumb Question about Manual Antenna
I have been a Pcar owner long enough to know the reason why the power antenna is on the right and the manual is on the left.
My question is...with technology getting greater, and the products getting smaller, does anyone know of a small power antenna that can be put on the left side?
Judy is pristine and I'm not sure if an antenna sticking up all of the time goes with the look.
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 10-17-2008, 07:54 AM
I couldn't find one when I replaced my manual a few years ago.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-17-2008, 08:30 AM
Typical Salesman
jeffrey2's Avatar
Me neither, but just got it back and am just...bugged at looking at it; it is a NOS one, but not as nice as a collapsed one.
Old 10-17-2008, 10:03 AM
midnight911's Avatar
how were the RHD cars set up?
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 10-17-2008, 10:52 AM
Typical Salesman
jeffrey2's Avatar
My guesstimation is they were set up as the LHD cars, the AC lines are most likely on the Left Hand side of the car.
Old 10-17-2008, 10:53 AM
Detached Member
Hugh R's Avatar
I'm guessing the automatic is on the right cause there is way more room for a motor. Why the put the manual on the left? My guess is that on LHD cars it's within reach of the driver's door. Just a guess though.
Hugh
Old 10-17-2008, 11:15 AM
Typical Salesman
jeffrey2's Avatar
It was for LHD cars, when parked at a curb, there is less chance someone will snap your antenna.
I know Mazda had a retrofit for their Miatas which had a similar issue, was hoping there was some cross reference-able retrofit. Bummer - I sold a windshield with antenna a few years ago figuring i could find a slender power antenna...
Old 10-17-2008, 11:21 AM
the the is offline
Put a plug or cap over the manual antenna hole (or just leave the antenna in, but down), and try this:
http://www.crutchfield.com/App/Product/Item/Main.aspx?showAll=Y&g=232750&i=12044UA200&search=antenna&tp=3449
Old 10-17-2008, 11:34 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Car wash ate my antenna. That’s what I get for being lazy I guess. My car does not have AC. Any reason I could not put a retractable one in the stock location? Would some consider this a bastardization?
Thanks,
Chris
73 911 E
Old 10-17-2008, 01:21 PM
does retractable mean electric?
I keep my manual one down.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-18-2008, 08:24 PM
Typical Salesman
jeffrey2's Avatar
I think he has the opposite problem?
I'm testing a few ideas, taking some measures and will advise if i come up with anything.
Old 10-19-2008, 07:44 AM
We specialize in antenna sales with lots of 356 and 911/912 experience. It's a gas filler issue not necessarily an AC issue. Just no room for the motor. Contrary to technological advances, power antennas are not getting smaller except if you compare a unit from the 50's with a current unit. If anything they are getting harder to access as antenna manufacturers are cutting out model specific units and making universal units with multiple mounting head kits. Heck, they work and look the same as the original and probably are much less expensive then the OEM unit. Just slightly different in overall specs. I was even informed from Hirschmann that I will not be able to order any more black antennas in the future. Something about the process or element used to make the black finish being outlawed in Europe or the sloughing off of this black coating is harming the environment, whatever? We do sell a cool power antenna unit with a flexible shaft which gives you all kinds of options when mounting but the simple solution is to just go manual retractable on the drivers side and if you need a power unit, use the passenger side for a very straight forward install. All sorts of replacements in stock from $19 to $85 power and manual, both fully retractable. Even Hirschmann antenna delete caps. Good luck with your project.
Charles
1970 911t
1962 356 S90
1964 Safari Rally Comet
Editor www.Bench-Racing.com
Old 10-19-2008, 01:01 PM
