1972_911T's Avatar
Help Needed On Bodywork
My car is in the body shop undergoing a full respray, Im just at the stage of trying to get all the panels/gaps lined up before it goes for finnal paint and im having a little trouble with the door window frame gaps. The guy in the bodyshop says its normal and they are all like it but I just want to check before it goes any further.
The problem is the front of the window frame starts off with about a 8 - 10 mm gap then this tapers closer to the A post up to the top corner where it is pretty close to the frame probably only about 3mm clearance in the corner. Ive tried to compare this to pics of other cars but its a very difficult area to see in a normal pic. I would be greatefull if anyone can supply some nice closeup pics or the gaps around the door window frame.
Thanks Steve
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 04-05-2007, 04:43 AM
1972_911T's Avatar
Anyone?
1972 911t RS Styled
Old 04-05-2007, 01:19 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Is it a coupe? That's what I would at least assume.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 04-05-2007, 01:22 PM
1972_911T's Avatar
Yeah its a coupe
1972 911t RS Styled
Old 04-05-2007, 01:25 PM
1972_911T's Avatar
No one can help with this?
1972 911t RS Styled
Old 04-06-2007, 01:06 PM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
Try PM'ing or searching for DarrylD. If anyone knows how to hang a door it's him.
Here's a thread by him on door gaps.
Door Gaps by DarrylD
-Jess
Old 04-06-2007, 01:08 PM
