WydRyd's Avatar
Exclamation Adaptronic aftermarket EFI system!
Check this ADAPTRONIC out guys
Looks like a very competitive product and should give MOTEC, Autronic, Haltech a good run for their money! Especially at ~$990 Australian!!!
Here's the feature list:
Features
Standard ECU features
"3D" Fuel and Ignition maps (as on any sophisticated aftermarket ECU)
Configurable ignition and injection outputs to suit different applications
Inputs for water temperature, air temperature, auxiliary temperature (eg turbo), manifold air pressure, throttle position, knock sensor, EGO (exhaust gas oxygen)
Outputs for four injector groups - allows full sequential injection on a 4-cylinder, or semi-sequential injection on a 6- or 8- cylinder.
Outputs for three igniter groups - allows for wasted spark systems on 4- or 6-cylinder, or conventional distributor systems.
Eight configurable auxiliary outputs - four of which are configurable as high current outputs, three of which are PWM capable.
PC interface
Field upgradeable firmware
Eight configurable auxiliary digital inputs
Datalogging via PC software
Special Features
Adaptive fuel control - with configurable tolerances and loop gains, and conditions under which adaptive behaviour takes place
Narrow-band (factory EGO sensor) closed loop fuel control
High current programmable outputs - allows direct drive of solenoid valves for boost control, air bypass etc
Special function programmable outputs - allows control of anti-pollution purge valves, air conditioners etc
Open-loop and closed loop idle bypass control - allows configuration of increased idle bypass amount based on low battery, electrical load, air conditioner, as well as correction based on RPM
Programmable for different crank angle sensor waveforms
Many other features
Technical Specifications
Attribute e420b e420c
Physical
Connectors 1 16-way OEM style plug for triggering and low current outputs
1 20-way OEM style plug for analogue and digital inputs
1 8-pin SIP connector for power and injector drives
1 6-pin SIP connector for high current auxiliary outputs
2 DE9 connectors for serial communications (one to connect to a PC/laptop, the other to connector to slave devices eg wideband oxygen sensor controller)
Physical Dimensions (mm) 174 x 92 x 50
Mass 0.4 kg
Looms available 0.5m long (for connection to existing loom)
2.0m long (for wiring directly to engine)
Sensor Interfaces
Crank angle sensor type 3 programmable inputs, configurable as triggering ignition timing, injector drive, ignition timing during cranking, or cylinder 1 marker.
Reluctor and optical/Hall effect inputs, with configurable edge selection, internal pull-ups on optical/Hall effect inputs
Crank angle trigger waveforms Sync / trigger / multitooth / missing tooth (versatile programmability)
Nissan optical
Mitsubishi style with 2 sync pulses
Manifold absolute pressure input 0 - 5V, 2-point linear calibration, range 0 to 400 kPa (requires external sensor, 5V supplied by ECU)
Air, water and aux temp inputs 4k7 pull-up (requires separate thermistor connected to ground), 8-point linearly interpolated calibration, range -127 to 127°C 4k7 pull-up (requires separate thermistor connected to ground), 32-point linearly interpolated calibration, range -30 to 125°C
EGO input 0 - 1V factory narrowband, or Bosch "wideband" - input impedance 10 MOhm.
Can connect 0-5V linearised sensor (eg PLX, M&W UEGO) to aux input
Can connect 0-3V Zietronix sensor to analogue input
Can connect M&W UEGO, TechEdge, Innovative to second serial port
Knock input High impedance input, bandpass filtered
Throttle position input 0-5V (5V supplied by ECU), 2-point calibration
Auxiliary digital inputs 8 inputs, each configurable as active-high or active-low, 12V tolerant inputs
Actuator Interfaces
Number of injector drivers 4
Injector driver waveforms Full sequential
Batch
Semi-sequential every period or semi-sequential every second period
Half/third/quarter speed full sequential
Fire all at once every cylinder 1 (as on Swift GTi, Alpine Renault)
Optional batch fire during cranking
Injector driver current Optional constant current or peak-hold drive, selectable steady-state current of 0.5A, 0.9A, 1.5A or 1.9A
Number ignition outputs 3
Ignition output waveforms Selectable as firing on rising edge or falling edge
Ignition output type Open-collector with 560Ohm pull-up (allows direct connection to OEM transistor or separate igniter box)
Number of auxiliary outputs 8: 4 high-current, 4 low-current
High current outputs Max current 7A (or 3A inductive), 3 of these PWM capable, PWM frequency selectable (23Hz - 2kHz)
Low current outputs Max current 200mA - suitable to drive relay coils
Control Characteristics
Map points 512 - every 500 RPM (0 - 15500 RPM) and 1/15th of maximum load (TPS or MAP) Same as e420b, but two ignition maps and two fuel maps.
Load determination TPS or MAP TPS or MAP
TPS using 2nd map as MAP backup
MAP using 2nd map as TPS backup
Both maps MAP or TPS, digital input to select
MAP and TPS map, digital input to select
MAP and TPS map, use MAP on closed throttle, otherwise TPS
Use max/min/average/sum (MAP, TPS)
Read TPS from map and multiply by value in MAP table
Injector pulse width resolution 0.7µs (0 - 44ms)
Ignition resolution 0.2° (0 - 51°)
Dwell time resolution 0.1ms (0.1ms - 5ms)
Dwell time reduction for high RPM with high dwell time
Accelerator pump TPS and/or MAP based (configurable proportionality) as well as asynchronous accelerator pump (function of RPM)
Works with TPS pot or switch - pot gives better performance
Fuel control strategies Open loop, closed loop, and two adaptive modes (requires EGO sensor) - can run open loop above a specific MAP if required, target AFR can be set across rev and load ranges.
Fuel correction Open loop, engine temperature, air temperature, accelerator pump, post-crank enrich, cranking enrichment, WOT As e420b, except that air temperature now has a temperature table rather than a fixed coefficient
Ignition control strategies Open loop, closed loop and adaptive (requires knock sensor, alpha version only) As e420b, but with temperature correction table for air temp and coolant temp
Idle control strategies Open loop values for hot and cold (2 points)
Target speeds for hot and cold (2 points)
Throttle cracker (VSS increase and change to open loop)
Extra for electrical load and aircon
Post crank idle-up Open loop values with a 32-entry temperature table
Target idle speeds with 32-entry temperature table
Idle effort correction for air temperature
Other corrections as on e20b
Main loop speed 200Hz approx
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-07-2006, 05:01 PM
Elombard's Avatar
Wow at that price and being a little creative on sensors and some of the less expensive ITBs it competes with PMOs doesnt it?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-07-2006, 06:13 PM
WydRyd's Avatar
Certainly does! I just paid $500 for a MAP-ECU piggy-back computer to eliminate the Carrera's AFM using speed-density sensing. This is only $500 more and offers me full fuel and ignition mapping
Certainly worth considering!
Curious, how would one setup the trigger on a Carrera engine? Does the Motronic use the Speed and Reference sensor that's on the flywheel to trigger the ignition?
If I fit a 964/993 twin distributor (my heads are already twin plugged), they already have a built-in sync signal right???
Merv
'89 911 Turbo Cab
Old 09-07-2006, 06:42 PM
rfuerst911sc's Avatar
A built and tested Megasquirt II version 3.0 runs around $400.00.Just a reference for cost.
Old 09-08-2006, 01:51 AM
Wer bremst verliert
JohnJL's Avatar
Crikey, those aussies are clever.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-08-2006, 02:18 AM
Elombard's Avatar
R Fuerst how much were the ITBs for your set up.
Old 09-08-2006, 02:28 AM
the megasquirt II are the best bang for the buck. Very well designed and work with a bunch of different applications. If I were to boost my own 3.2 I would do the mega squirt prior to anything else. I was so impressed with the tunning process when I boosted my 3.0 with the mega squirt I would only go that route if to do it again
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 09-08-2006, 05:17 AM
Elombard the ITB's were $1100.00 and that includes the fuel rails and a fuel pressure regulator. Then add $86.00 for a TPS sensor and $250.00 for 6 velocity stacks = $1436.00. I used some old Weber manifolds I found cheap and was able to use the OEM throttle linkage from a carb'd car.
Old 09-08-2006, 10:57 AM
Elombard's Avatar
Holy cow so you have modern programmable FI with ITBs. You could build a wild motor withthat set up and it was only $2K!! Thats fantastic. I am surprised any body buys PMOs any more. Heck thats barely more than a nice complete set of used webbers.
Old 09-08-2006, 07:51 PM
Well there is more cost as you have to buy air cleaner housings and filters,fuel injectors,wiring harness etc. plus I went with a relay board. When I add up everything I'm around $3100.00 or so and that is buying some items used.You also have to configure fuel lines and I went the extra mile and used ss braided hose with ss fittings, this is overkill but I didn't want any leaks.There's also engine temp sensor,air temp sensor and lots of little items. Still money well spent for tuning capability,throttle response and the look of the engine compartment is amazing compared to CIS. You can save more money if you build the ECU yourself.
Old 09-09-2006, 04:48 AM
WydRyd's Avatar
Just an update on this, the dealer has quoted me AUD$2k to install and tune this system on my car, which equates to approx USD$1.4k
That's a pretty good deal for a complete standalone engine management system, with features that's on par with Motec and Autronic EMS's.
Certainly worth considering...
Merv
'89 911 Turbo Cab
Old 10-16-2006, 09:22 PM
Wer bremst verliert
JohnJL's Avatar
I run this on my car now and am mostly happy. Everything works as advertised and Andy is a great guy, however it does NOT support EDIS. That required acquiring Haltech ignition units to drive the EDIS coils, but works good now.
Nothing like having the designer/manufacturer 2 kms from your house...
Old 04-04-2007, 02:40 AM
Here is an even cheaper way to add ITB's. Suzuki Throttle bodys, in this case from a GSXR 600 which will be good for the NA 2.7 I am building. By taking my time I picked up a pair on Ebay for <$100.00, add a fuel rail for $50.00 plus a pair of weber manifolds for $125.00, and $100.00 worth of misc parts and some work. I may or may not use the Air Horns shown, but they only cost $96.00 for the set and are available in a range of heights.
Of course you still have all the other usual stuff you have to buy like fuel pump, injectors (I used Honda injectors as they fit the suzuki injector bungs) etc. But the throttle bodys themselve are cheap, even if you have to go to a Hayabusa set for a large bore motor you can get a pair for $400.00.
Robert
Currently Porsche less (but the wife has 2)
Old 04-05-2007, 04:37 AM
